Question about Poulan Pro Chain Saw 46cc 20"
Gas adjusted wrong
Where can I buy the special wrench or scewdriver needed to adjust the gas flow. The saw has been adjusted by local service tech and he apparently doesn't know how to adjust it. If there is a special tool for the idle where can i get that and how much will these tools by including shipping and handling.
thank you in advance.
    Problem Solver:
  • 6 Answers
Most chainsaws are built so all the adjustments are easy and basic. A standard flat blade screwdriver should be all you need to address most carb problems. Your problem is more likely the fuel mixture, the ratio between gas and oil. Check your owner's manual and replace your fuel with the proper mix..
Posted on May 26, 2010
My Rancher doesn't maintain high rpm. What's wrong?
Most 2-cycle chain saws have 3 carburetor adjustments; idle speed, low RPM fuel/air mix and high RPM fuel/air mix. The fuel/air mix needle valves will probably require a "special" driver tool to adjust them. Be careful with the adjustments, you can really mess things up by incorrectly adjusting them, then your saw goes from running poorly to not at all.
Apr 04, 2015 | Husqvarna , No.455 Rancher, 20" Gas -...
Adjust McCulloch MAC-3516 Gas Chainsaw
Adjust what exactly? I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Aug 15, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
It keeps stalling on me
This could be one of many problems:
To start, is this the first time you have used the unit in a while? Did you store it with gas in the saw? How old is the gas that you are putting in? The factory call center will tell you that today's gas is only good for about 30 days before you should use it. If it is old gas, get new gas, make a new mix and try again. If that doesn't work, check your air filter. If the air filter looks good, the carb either needs a good cleaning or an adjustment. The newer poulan saws require a special tool to make the adjustment. If this is a newer saw (1 year or less), 1 carb adjustment is covered under the warranty. You can find the list of authorized service centers on poulan's website. Without a model number, I can't help you with specifics on where the air filter is, etc. I hope this helps.
Aug 28, 2011 | Poulan Garden
Proved saw is firing, acts like it is not getting enough gas, need to know proper procedure for adjusting carb. and what the two adjustments marked L and H do. Looks like it takes a special wrench, need to...
If the saw has a EPA carb it will have anti tamper screws, these have a spline on them, not a screw driver slot, there is a special tool to adjust the jets part no. 530035560, check the web for sellers, both screws are fuel screws, not air screws, so the more you undo them the richer the mixture gets, the L screw will adjust the mixture from idle up to half throttle, the H screw will adjust from half throttle to max rpm, all saws today are set for the best emmissions not the best running so they are always set on the lean side, the settings as they are will be a good starting point, if the saw does not pick up clean inscrew the L screw a bit at a time until it does, be very carefull with the H screw as this can be leaned off too much and the saw will over rev and possibly seize, this should be do with a taco so as you know what the rvs are, it should not exceed 12500 rpm.it should aleays sound a little rich at maximum no load revs.
Jul 23, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Can i alter oil flow to chaimac 436
Most hobby saws do not have an adjustable pump, if it is adjustable there will be an external screw close the the clutch and sprocket, would would not need to remove the bar and chain to acsess it.
Feb 12, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Where can I buy a wrench to adjust the carberator
Normally you would need a screwdriver.But the adjustment screws on your saw have plastic caps on them that will only turn about a1/8 of a turn.these are pre-set at the factory.you will need too take carb off and clean it out.if that doe,s not help it needs to be rebuilt or replaced.
Dec 03, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I have a new Husky saw that does not maintain accelleration. I'm operating at 7,500 feet above sea level. And apparently you need a special tool to adjust the carb? And there is nothing in the manual on...
All modern saws are set to operate very lean at sea level (thank the EPA). If you bought it locally take it back to your Husqvarna dealer, he should adjust it without charge. If purchased at a big box store or on line I'd take it to a dealer at the altitude where you use it and ask them to adjust it. there will be a fee but running it to lean will cause it to fail. A few dollars spent for an adjustment will certainly be less expensive than a new saw.
Lou
There are tabbed plastic caps on over your fuel adjustments. Thank the EPA once more.
Sep 04, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Jul 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Poulan Pro Chain Saw 46cc 20" Logo
186 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
