Question about Linksys Wireless-N WRT150N Router
Cannot conect to router
Signal gose in and out
  • 813 Answers
Here is anthor link for u
http://www.mindspacesolutions.com/html/router_config.html
see it
i thnk ur problem will solves
Posted on Apr 07, 2008
SOURCE:
I am having troble conecting my vcr to tv, dvd plarer and Virgin cable box. Auto set up didn't work and I cannot tune in manually. To make matters worse the vcr thinks my video channel is channel 4 whereas...
try this unhook it all start over first hook the cable box up to the vcr witch would be the wire that says out of the cable box gose in to the ant on vcr the tv cable from the vcr gose to the back of the tv the dvd player gose into the rca jacks on the rear vidio audio in just match up the colors make sure all cables that screw in are snug up as it will degrade the signal if to loose then go to set up in the vcr and if it has a auto option for set up use it . hope this was helpfull
May 28, 2010 | Sony SLV-740HF VHS VCR
Loses connection w. remote computer I have a laptop one room away. The laptop accesses the internet and printers from this location. Most of the time it works. However, it will suddently lose the conection...
Check if this router is stronng enough interms of it signals. Check on the laptop the signal strength of the conenction.
If the signal strength is poor you can either move closer to the wireless router or vice versa or can get an access poitn to boost the signal.
Please rate if helpful.
Thanks
Apr 09, 2010 | NetGear WGR614 Router
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
My DIR 655 is able to conect to my laptop through wireless
Do you see wireless signal of your router from your Laptop? If not! make sure the Wi-Fi of your Laptop is activated for you to get online wirelessly.
Mar 07, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Looks like conected but i cant get internet
Router might not be set up with the modem. Your router broadcast wireless signal when it is powered on, so even if it is not connected to a modem(where you get your internet from)you will have a local connection. That's normal. You need to set up the router. Call linksys technical support, if they cannot help try http://technicalsupport.blog.friendster.com
Feb 24, 2009 | Linksys Wireless-G Broadband Router
Low signal (amber Light0
restrt your wireless router.
Jan 03, 2009 | NetGear WGR614 Wireless Router
Router to computer issues WRT54GS
Ensure that any firewall you may have is turned off, then try it again.
Oct 26, 2007 | Linksys Wireless-G WRT54G Router
Please help I can't conect to Router MR814V2 with wireless card Encore ENPWI-G2
On Windows XP, the OS will prevent a connection to an unsecured wireless network such as what you have.
You can try:
Double click on the red WiFi icon, click on the "Change the order of preferred networks",  Click on "Add", type in the Network name (SSID) of your router (you can get this by using the connected PC and log in to the NetGear's Webbased Interface), set Network Authentication to "Open", set Data encryption to "Disabled",  OK, reboot your PC.
Alternately, you can set the PC where the Encore ENPWI-G2 card is connected to manual configured settings rather than Auto obtain. Follow what is in the connected PC's settings except that the  last number of the IP add be different (ex. connected PC > 192.168.0.100, set the unconnected PC to 192.168.0.101, all the rest subnet, default dns be the same. Of course the 101 must not be in use, if double IP add, change to 102).
In some instances, you may need to use the Encore WiFi configuration utility (normally comes with the drivers in the installer CD) rather than the Windows buil-in WiFi Config utility,
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 10, 2007 | NetGear MR814 Wireless Router
Linksys Wireless-N WRT150N Router Logo
19 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
