Question about Minolta Maxxum 400si 35mm SLR Camera
Ive recently purchased an OPTEKA 650 TO 1300 MANUAL FOCUS ZOOM LENS my camera is obviously in af mode and every time i try to CLICK a picture it wont click. what do i do?
  • jstaubsjr May 26, 2010
    how do i change my minolta maxxum 400si from auto focus to manual focus for my new OPTEKA 650 -1300MM ZOOM LENS and then back to auto focus for my other lens ?i am new to this .is there anything else i should know?
    Genius:
  • 1,040 Answers
Dear Jstaubsr,
your camera as well as lens should be capable of auto focus.... in other words auto focussing is also dependent on your lens.
Since your lens is manual focus. It will not work in auto focus mode.
Posted on May 26, 2010
  • 4,889 Answers
You have mentioned in the problem that you are using a manual focus zoom lens. It means that the camera cannot utilize its motor to auto focus the lens. You should put your cam in manual focus mode and take a picture.
My rebel T1i won't take pictures on AF
If you have a specific zoom lens on and it will take shots in MF manual focus but wont in AF auto focus you could have a broken ribbon connector in the lens. Try with another zoom lens if you get the same problem it could be the camera. If it works OK then the ribbon in the affected lens may need replacing.
Jun 16, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Telephoto opteka instructions
There are several reasons why you have to use this lens in manual mode. There is no chip in it and no focus motor. But even if there was a focus motor, your camera could not focus automatically, because the highest lens opening (smallest aperture number is f/1:8 on 1300 mm it is even f/1:16) Your camera only can focus on AF if the aperture is or is smaller than f/1:5,6. For the rest, you should chose the M on your mode dail. and then you can just press the shutter release button. Look on the screen how the histogram looks. If the histogram is to the left, the picture is to dark, so you should choose a longer exposure, if the histogram if far to the right, the picture is to light, so you should choose a shorter time. Have fun.
Nov 24, 2013 | Cameras
Quantaray 600-1000mm Telephoto Zoom Lens FOR NIKON work with D3100 in all modes?
The lens is a manual focus lens. It doesn't matter which mode you have the camera in, you'll still have to focus it yourself.
Nov 16, 2012 | Quantaray 600-1000mm Zoom Lens
I did not get any instructions with my Opteka. Have tried to take photos with it. But they came out all blank. I used a tripod. Would like to know where I can down load instructions. Certainly not as good...
You did not provide enough information to determine what your problem is. For example, were the pictures all light or all dark. Knowing this lens, I will assume that they were all dark. So...
1) This is a very, very slow manual-focus lens. It will not auto focus. It must be manually focused very precisely because it has virtually no depth of field.
2) Depending on your camera, your internal light meter may not work. On my camera (Nikon D-90), it does. If it does not on yours and I suspect that may be your problem, you're going to have to shoot everything manually, i.e. setting the shutter speed and lens opening yourself. You can use your internal light meter to help you get started by taking your light reading before you install the lens...preferably using the aperture only setting where you set the aperture at f8 which I think is the speed of the Opteka and let the camera set the shutter speed. Make a note of the shutter speed then attach the Opteka to the camera and mount the lens on a tripod with the camera attached.
Then set your camera mode to manual and set the aperture to match the lens (f8, I think). Set the shutter speed at the speed you noted earlier. Shoot a picture using a remote shutter release or the self timer. This lens is so slow that unless you're in exceptionally bright conditions you will get fuzzy pictures due to camera movement at full zoom of 1200m and above if you're using the 2X doubler. I would start shooting at minimum zoom of 650 without the 2X doubler. Shoot a picture. and check the result.
You should have an image but it may be too light or too dark.
If its too light you'll need to increase the shutter speed or stop down the aperture to, say, f11...or both. Make the adjustment and shoot another picture. Remember that if you increase the aperture, you increase your depth of field, making focus less critical. If you increase the shutter speed you make camera or subject movement less critical.
If it's too dark, you can only increase the shutter speed because you can't open the lens any wider than f8. Make the adjustment and shoot the picture.
Keep doing this until the pictures are the way you want them.
This is a decent lens for the price and worth the little money they cost if you can't afford $10,000 plus for a high quality telephoto lens of this size. I would forget about the 2X doubler because as others have said, it further reduces the speed of an already very slow lens with such a high rate of magnification that a knat landing on the lens could cause the picture to blur from movement.
Jun 26, 2011 | Opteka 650-2600mm High Definition...
When i press to shoot a picture, the focus is moving back and forth. sometimes it will take a picture, sometimes it does not come into focus and will not take the picture. I have charged the battery...
Hi, check af mode settings in upper display ;set afs,central af area clean contacts of lens cpu and in body too. Set the manual focus mode and check in viewfinder if the focus indicator LED light no flashing.Can make focus your camera dont have problem ,the lens may need maintenance (clean) or repair.
Greethings!
Feb 19, 2011 | Nikon D80 Digital Camera
My lens stopped working in Auto Focus mode. I can take a picture in manual but I can't seem to focus clearly. I prefer using auto focus for my everyday pictures, but the lens will not work. I am sure it...
there is couple of possibilities like wise when you zoom lens manualy and can you heard the hard noise then could be AF unit itself faulty. AF unit gear is gone.
could be AF shaft broken thats why not focusing
could be AF Flex broken thats why not focusing
for that please bring to canon service center
Aug 11, 2010 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Opteka 500mm f/8 mirror lens for my DSLR and it's says no lens
You need to turn the mode dial to Manual (M). You won't be able to use the camera's built-in exposure meter at all with this lens. You can take an exposure reading with another lens to use as a starting point, then review the pictures and histograms to fine-tune the exposure.
Feb 26, 2010 | Opteka 500mm f/8 for Canon EOS
I have purchased a maxxum 450si
You have a film camera, you should have AF lenses. The AF lenses are larger round then older manual lense as you can have the older Minolta lens will fit the newer cameras, just not auto focus. If your AF is not working with AF lenses, I will assume you have power to the camera (batteries) These camera are not hard to use. To AF the camera, press the shutter down slightly (you can try without film) and it should focus on the center of your shot. Indoor and under low light, they will have trouble with these older AF bodies.
May 08, 2017 | Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 400si 35mm SLR Camera Logo
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
