Where is the temperature senor unit - Heating & Cooling
  • 11,800 Answers
It's in the air intake for the evaporator  - the radiator that cools the air. If your aircon is a standard split unit it will be at the top immediately under the air filter.
Posted on May 26, 2010
  • 10,865 Answers
Hello. Every manufacturer has a slightly different location but generally the sensor is near the compressor. J.
E4 error on UberHaus 4 in 1 portable air conditioner model PC08-AMD11
You have to check the temperature sensors. Room temperature sensor and coil temperature senor.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 27, 2016 | Heating & Cooling
Room temperature senor not working
Hi Karl,
I hope the following links is helpful to you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 24, 2015 | Fujitsu ASU30CLX1 Single Zone Wall...
The dryer timer stopped working
Is that a temperature senor in the GE spacemaker Laundry dryer? My dryer stops spinning when it gets too hot. After it cools down, it will spin and dry again.
Jan 05, 2013 | GE WSM2700W Unitized Spacemaker Washer and...
Aqualink RS4 Water temperature reads 120 - obviously wrong.
No but this sensor is easy to replace. Just pull the sensor from the pipe by loosening the staniless steel clamp that holds it in the pipe. Then follow the wire back into the Aqualink box and unplug. Get a new one at your local store and replace. It's a common problem and you should be able to do it with ease.
May 21, 2010 | Jandy Aqualink Rs4 One Touch Control...
Where are the water temp senor and sending unit located on a 3.0 cyclinder motor?
the coolant temperature sensor is located near rear of engine block thermostat .... Thanks
Mar 05, 2010 | 1999 Ford Taurus
Should the LG LS-K-1830CL outdoor unit ice over on the coils when operating in the heat pump mode? Would this cause the unit to not properly heat the room?
Running the heat pump in low outside ambient temps. will definitely cause the coil to ice up. An ouside temperature senor or a wind baffle should be installed in climates that get below freezing. This would definitely cause the heat pump to operate at lowered efficency and maybe not at all. It should go into defrost mode if the sensor is working correctly when the coil ices up.
Dec 20, 2009 | LG LS-K1830CL Cool Mini Split Air...
Throttle position sensor is closed how do I repair? Where is the cooling temperature senor located?
if the throttle postion sensor is reading closed you will have to replace the sensor check for power and ground at the sensor there should also be a 5volt refrence signal sent from the pcm......the coolant temp senor is located (looking under the hood) on the right side driver side next to the end of the upper hose
Nov 29, 2009 | 2000 Ford Focus
Engine Coolant Temperature sensor
choke stuck . check and see if the car has a senor on the carb and spray around the base of the carb . but i think the high ide senor is bad .
Jan 21, 2009 | 2000 Saturn SL
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
