Question about HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP PC (Intel Core 2 Duo T7500 2.20 GHz/4MB L2 Cache, 3GB RAM,... (RM922AAR1)
Blank screen,pwr sup appears to ok, fans runs, pwr light on
My hp pavilion dv2500, when you turn it on the pwr light come on,but no display. I check to see if the caplock would turn off and on with no success, also it came up once for about ten min then the screen turn white and one min later it went completly blank. After this the display never came back. What may be the problem and how can I fix this.
    Scholar:
  • 58 Answers
The issue seems to be due to defective video card on the notebook. Connect and external monitor to the PC and check if it works fine or not. You can follow the steps listed below to connect an external monitor.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your PC is under warranty, contact HP to get available options to get the notebook repaired under warranty.
Posted on May 26, 2010
Hp pavilion dv6700 has blank display
If you have access to a monitor plug that into the laptop and see if you have a picture if you have it probably the invertor that lights the backlight its behind the screen at the bottom
cheers
Sky
Jun 08, 2014 | HP Pavilion DV6700Z Notebook
My screen goes fuzzy sometimes, and sometimes it shows double displays on one screen, it acts retarded or something. I have an hp pavilion dv2500
Could be one of four things:
  1. VGA cable from screen to the motherboard is loose or connection damaged, needs inspecting
  2. Display screen is failing, try this laptop on an external monitor, if display is ok, then at least the next problem is not the issue
  3. If the display on an external screen is just as bad, your graphics chip is going bad. On HP laptops, they use nvidia chips, which all seem to suffer due to overheating. If this is the case and you act quickly enough by stripping the laptop and cleaning out the cpu fan assembly and heatsink, you may get it working normally. If this fails to cure it, you will need to have the motherboard graphics chip "re balled"
  4. Bad graphics driver (least likely), download the latest graphics driver for this laptop
Jul 22, 2011 | Computers & Internet
Hp dv2500 wont turn on
does the laptop plug in tightly to the power socket
if not the pavilion part to get the system power needs replacement
contact a local technician and state the power adapter plug-in on the motherboard needs replaced
these commonly go bad on pavilions
it should cost you less than 100usd to repair
or rma the laptop if you have warranty coverage left on the hp dv2500
good luck
Sep 28, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I have a HP pavilion Entertainment laptop and recently the screen went blank while the power was still on. I restarted and the screen continued to stay blank. I then turned the laptop off and unplugged it...
The connecting data bus between ur laptop monitor and ur motherboard has either been at fault or else there has been some problem with the wire connection between the two......i.e it has been loosen up....
Get ur laptop checked from the hp representative and if possible get ur laptop insured under different laptop policy schemes.....
With Regards
Abhineet Raj
Jul 29, 2009 | HP Pavilion dv2000 Series Laptop Full...
How do I turn on the webcam for hp dv2500
Here's a page with many solutions for webcam problems on the dv2500:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01560721&lc=en&dlc=en&cc=us&product=3369421&lang=en
Hope this helps!
Mar 28, 2009 | HP Computers & Internet
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Audiovox FPE3000 turned off sponataneously and will not turn back on
I would suggest getting a schematic of the set and using a multimeter looking at the power supply test points to determine what is happening exactly with the power supply.
Sep 08, 2007 | Audiovox FPE3000 30 in. HD-Ready LCD...
HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP PC (Intel Core 2 Duo T7500 2.20 GHz/4MB L2 Cache, 3GB RAM,... (RM922AAR1) Logo
857 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
