Question about Kenmore 44102 Front Load Washer
Power outtage at my house caused my front load washer to stop working.. can this be repaired or would it be a better investment to purchase a new one?
  • Kenmore Master
  • 1,527 Answers
Hello it might have blew the glass fuse in side the washer it's located on the power supply board .but beware if you put another 1 in and it blows again then theres a dead short somewhere good luck
regards
shaun
Posted on May 26, 2010
Kenmore elite he3t front load washer has no power. Replaced ccu, worked for a few minutes then stopped. Unable to power up
I would guess you have a short in the machine somewhere and likely have fried the new CCU also. If you want to and have the ability, you can track down the short and fix that. Then you will probably have to purchase another CCU before it will run. Wish I had better news. Good luck.
Jun 22, 2016 | Kenmore Washing Machines
My Duet GHW9100LW I turn it on and the dial light just blinks, it does not lock or start. Tried unplugging, did not work. Don't have manual. Is there a reset button?
Could be a bad lock or possibly a bad control board. I run into this all the time, working for a maytag/whirlpool dealer and repair facility. If your in a area that has alot of power outtages or surges get a surge protector after you get your problem fixed.
Feb 19, 2011 | Whirlpool GHW9150 Front Load Washer
Model LGWM2277H purchased 2005 - Since 3/19/10 LE Code Continues
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 18, 2010 | LG WM2277H Front Load Washer
I have a front load frididaire washer purchased new in May that has stopped working for the second time- mid cycle- the last time it took three weeks to repair- is there a lemon law on washers
often times thear is but hard to get,,3 times same issue within a year,,,in the meantime buy a american car..all this importing of stuff is why we have junk appliances
Dec 23, 2009 | Frigidaire ATF6000ES Front Load Washer
My kEnmore front load he2 plus washer is flashing f-28 does anyone know what this means?
F-28 refers to Communication Error.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
- Check connections of the CCU board within the housing.
- Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test
or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Note - The cost of CCU and MCU is more than $200 each. You cannot replace a part of CCU and MCU. The complete Set needs to be changed. If the Washer is more than 4 years ( which i assume, as this Error is usually after 4-5 Years ), it is better to Invest in new one than Repair.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 06, 2009 | Washing Machines
Power outtage now the washer door is stuck on locked and we can't get it open even though the cycle has completed
take the front cover off of the washer section you will be able to see the lid switch on the right side un plug or turn off the power pushe the lock arm over you will need to replace the lid switch
Jul 03, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
After power outtage my f/p washer is dead -no lights nothing
Only reset is to unplug it. Are you sure you have power at the outlet? If you have 120V at the outlet the power surge may have blown the controller, not a cheap fix :(
Apr 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Power outtage
you can reset the machine by following the instruction on the owner's manual.
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 44102 Front Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
