Question about Nikon Coolpix 2200 Digital Camera
Pictures go "pink"
All my photos have a definite "pink" cast to them. Much too pink to ignore. If I leave it turned off for about a week with the batteries out, then it may return to normal, but as soon as I take a photo in conditions that could remotely be called 'bright' it goes pink again. reseting doesn't hepl
  • deanjs Apr 07, 2008
    WOW that was quick
    No set tint levels in the camera, just preset brightness and daylight-incandescent etc levels. I've played with all those already-no go.
    Looks like it will have to go back then as I don't want to have to "photoshop" all my photos. (I get pretty click happy on occasion) and it did work originally just fine.
    Thanks anyway
    Thanks-I've tried the reset and there is no change. I've tried all the brightness, daylight to indoors settings etc. Its only a pretty basic camera-point and shoot really, but it took pretty good photos (did!). I think its hardware not software problem, but I was hoping......
    Thanks for your time and sugestion
  • 477 Answers
Have you tried the camera reset feature in the setup menu I have found resetting the camera sometimes helps with this. If it does not help it is most likely a ccd issue the is not processing the yellow and blue correctly. I have a feature on my camera that causes that effect so the reset should fix it.
Posted on Apr 07, 2008
  • 78 Answers
This could be a native color cast of the sensor. Is there an option to set tint levels in camera? If so, simply push the slider over to the 'green' end until it looks right.
This can also be done with basic photo editing software.
If this is an issue you need solved from the hardware end, Nikon is your friend. It's at least worth the 10 dollars to send it back to factory to find out if there's something wrong with it. Check out for a list of authorized service centers near you.
My pictures have a purple tint to them
You're either using old/expired film, or taking photos during dusk. Color film is balanced for daylight photography. Using it under conditions other than that will result in varying color casts on the resulting images.
Fluorescent lighting: Greenish
Indoor bulbs: Reddish/orange
Outdoor at night/dusk: Blueish/purpla
Ourdoor at dawn: Pink/blue
Or, you may have just gotten bad print work done. Try a different lab.
Jun 12, 2011 | Canon EOS-AE-1 35mm SLR Camera
Yeah it is helpful yet definitely needs pictures, I've opened up my 3004...
The guide to fixing your PSP screen the easy way!!!!!
This Guide will give you simpleinstructions on fixing the psp screen with little to no stress. Besure to keep all your things in one place and try to do everything inone sitting or at least do it in a area where you know somebody won'tknow knock the parts to the floor as there is a lot of small screwsand thing. Try to use a small box or pan to keep screws and otherparts and keep yourself grounded but keeping parts of yourskin(unclothed)to something made of metal.
1) Flip you PSP to its backside and besure the back cover that holds the battery is off. There are twoscrews in back of the battery. On could be covered by a sticker. Besure to peel it of slowly as it will void you warranty if it isruined.
  1. After you get these out look on the bottom side,you will see a screw that is dead center of the psp. The last two are above and below where the memory card slot is.
  2. Take the faceplate off. Now you will see a a small set of buttons on the screen. To the right of it
    is a small cable. Use a flathead screwdriver to the clasp and pull the cable out.
  3. You will now see two clamps for the screen where the button assembly for the d-pad is. The same thing for the other side where the face buttons for the psp are. Take all the clamps off by use the flathead screwdriver again. Put in in between the screen and clamps and give it a little turn.
  4. You have the screen out now. Pull it from both sides very slowly. Be very careful as there are cables still connected. Flip the screen out as we are going to take the cables off the screen now.
  5. There are two black clasps holding the screen cables on there. Lift them up(slowly!)and take the cables off. If those claps are broke there is no fix outside a new motherboard so don't break them.
  6. Put the screen into the clasps putting in all necessary cables that were went thru taking off. Sit the LCD screen snugly and and lock clasps. Return faceplate and all buttons to original positions to be sure everything will play right. Before you close it all up be sure everything is in place and fits well. Be sure to put the buttons back on and connect it to the motherboard. Turn the psp on and be sure it all works well. If it is having any pronlems go back over each step in reverse order from when we put the screen in.
  7. Once you go get the screen working put the screen back on and tighten all the screws.We are all done!!! Enjoy your PSP and I will see you online in Resistance!
Hey guys, If anyone wants to help me get some pictures up shoot me a comment on here. My digital Camera died today and it will be awhile before I will buy a new one(maybe its good because since my PSP is still under warranty)thanks!
on Jun 06, 2010 | Sony PlayStation Portable (PSP) Console
Pink cast to pictures
Test to see if this phenomenon repeats in all dif. SCN and AUTO mode.
Test to see if the flash could be causing it.
2 outdoor photos: One w. flash one without
2 indoor photos: One w. flash one without
If this phenomenon has a patern you should specify this if repair needed.
KODAK Contact:
Oct 04, 2009 | Kodak EASYSHARE M1063 Digital Camera
Pink cast in images from NEC VT540/440 projector
Sounds like one of those problems only cureable with expert knowledge of for example Chroma feed , Lcd function , lamp luminence, not to be a killjoy but it sounds like this is one for the engineers an estimate should be free and even if you dont have it fixed you'll know whats wrong if you want to do it yourself providing you have adequate training of course .... Regards vortash
May 08, 2009 | NEC Office Equipment & Supplies
Photos are turning out pink and green from my powershot A85
Its is bad ccd imager known problem in Canon A85 camera.
Canon will repair A85 free of cost in ccd imager problem.
Click Canon CCD Imager Advisory for details.
Apr 22, 2009 | Canon PowerShot A85 Digital Camera
My pictures have a pink cast to them
This is a symptom of a faulty CCD. This is a known issue and if the camera is taken direct to a Canon service centre they should be able to have it repaired at no charge. Camera shops can also send them in for you but will most likely charge you a handling fee.
Apr 12, 2009 | Canon PowerShot A95 Digital Camera
Overall pink cast and pink stipe at top of all images taken.
Never had that camera, however, had the same problem -- the pink stripe and pink cast. Turns out the lens cover was slightly cracked and not opening and closing properly. Thus -- the pink cast.
Mar 26, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Pink viewfinder screen and pink photos
I am afraid your CCD is faulty.
No diy possible unless you can find a working CCD-chip.
Dec 20, 2008 | Fuji FinePix S5000 Digital Camera
Reddish cast in photos, white objects look pink.
Hello dcmassey, the cause of the problem can be CCD imager. So, the best solution is to claim for Sony recall. If there is some other problem ask for the price estimate. Please contact the nearest Authorized Sony Service. Best regards, Arpi
Mar 14, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Nikon Coolpix 2200 Digital Camera Logo
208 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
