Question about Westinghouse L2046NV Monitor
Screen Comes on and goes blank within 3 sec
When the computer powers on the screen immediatly goes black within 3 sec of showing the screen.I tried a different monitor and it works fine. So it is not a cord issue. It is a screen issue. What could be the problem?
  • 11,361 Answers
Look for bad caps (bulging/leaking tops) in the power supply first, it may have taken out the fuse and transistors in the inverter circuits also.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 26, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Hp f2105 black screen after 2 sec on?
You've asked this question in two places. This is confusing--try to ask it in one place only.
I answered it in your other request.
Nov 20, 2011 | Rosewill R700J 17" Flat Panel LCD Monitor
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Monitor only stays on for 30 sec. & then goes off then if I remove the power cord & re-power it up it comes on for another 30 sec. then goes back off
Howdy folks. There are only 3 things that can go wrong with a screen. Since you both are experiencing the same symptoms, let's ask the same question: When the screen goes blank, is the power button still green or is it orange? A green light indicates a good power supply and a bad screen. An orange light indicates a bad power supply but a good screen. I used to take them apart and try to fix them but they just aren't worth the trouble because they are so inexpensive nowadays.
Either way, I'm the bearer of bad news. It looks like you'll both be getting new screens. Please don't hold it against me when you rate my solution! ;-)
Jan 04, 2009 | E-Machines eMachines Monitor E15T4
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Hmm... is still not working
Start your computer and tap the F8 key as soon as the computer begins to power-up. Keep tapping until you come to the Safe Mode screen. When the screen alerts you to the fact that you have chosen Safe Mode, click OK.
When you get to the desktop go to the control panel and launch System Properties. Go to Hardware and Device manager. Click the arrow next to the Display Adapter. Point at the adapter, right click and chooser Properties. Click the Driver Tab. Roll back the video driver to previous driver.
If indeed you have installed a new driver that is not compatible with your video card, then rolling it back to the original may very well take care of this problem.
Aug 14, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
Monitor is blank/black
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT)
who is not "technically inclined." If you really want to fix this
particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | Star Logic 17" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Westinghouse L2046NV Monitor Logo
321 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Dudeman321
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
