Question about Karcher 1750 psi Electric Pressure Washer
Low pressure on the pressure washer
Low pressure on the karcher electric pressure washer . Ran fine last fall. stored in shed.
  • Anonymous Mar 22, 2014
    last time I used was working fine
  • 553 Answers
Most likely your "O" rings or seals have gotten hard and are leaking. Sorry I don't know your equipment well enough to tell you how to change them but you can most likely find the info at your manufactures web site.
Posted on May 26, 2010
My Karcher 720mx moter is working fine but i have no water pressure coming from pump
hi put some silicon spray in inlet and outlet then reconnect hoses what is going on is when you store it the seals start to dry out.........
Jan 13, 2011 | Karcher K3.68MR Electric Pressure Washer
I left my electric karcher pressure washer it in the shed during the winter and they tell me that the housing and the safety valve need replacing. Can I repair it myself? They want 180.00 to fix it which...
Is there a leak from the bottom ?
If so then there is a crack in the Manifold housing. A New Manifold Complete Replacement is approx. $61.03, can be purchased from Karcher.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
Apr 29, 2010 | Karcher PSI Electric Pressure Washer
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
NEW KARCHER KB6060 ONLY RAN FOR 10 MINUTES
Take it back to Argos. They will either replace it or give you a full refund, no questions asked. That's my experience anyway.
May 05, 2009 | Karcher PSI Electric Pressure Washer
Karcher 1750 psi Electric Pressure Washer Logo
947 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
