Question about Swintec 7040 Typewriter
Swintec 7000 typewriter
Carriage sometimes won't return to the left margin unless I turn it off and turn it back on.
  • Anonymous Apr 25, 2008
    Have not tried anything - do not have manual. Have to turn typewriter off
    to return to right margin.
    Please give solution - my email address is ms.tis@sbcglobal.net
Lo and behold, some light oil on the stainless bars solved the problem.
Posted on Apr 08, 2008
Thanks for the tip about the oil. I was having the same problem and that took care of it.
Posted on Apr 25, 2008
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
How do I unlock right margin on a Swintec 7040 typewrite?
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
razors
Nov 03, 2011 | Swintec 7040 Typewriter
My Swintec 7000 typewriter will only go half way over and beeps. It wont let me go any further unless I start a new line HELP!
The R. margin is probably set there. Go to the stopping point, press but don't hold the mar rel key, space to desired location, press R. mar key.
DickyO
Mar 03, 2011 | Swintec 7040 Typewriter
My Swintec 7000 will not let me tab further than an inch from the left margin. All attempts to clear it have failed. Tab Clear and Margin release have not worked. Thanks, John
Tab to the R. stopping place press don't hold the margin release key space to the locationyou want the R. margin press R. margin key.
If this dosen't work turn off the machine and check to be sure the carrier will move back and forth. Put a few drops of WD40 on the silver shaft the guides the carrier.
Merry Christmas,
DickyO
Dec 21, 2009 | Swintec Office Equipment & Supplies
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
Swintec 640 margin release
If it is the left margin, you touch the carriage return button to find the current position of the left margin, then touch the mar release button and backspace to the new left margin location, then depress the left mar key. You should here a beep. You are done.
Jul 22, 2009 | Swintec 7040 Typewriter
Margin release
Turn the typewriter on press the return key. If you want the margin to the left of were it is set press the MAR. key ( margin relace) press the back space key to the desired spot. press the L margin key. Your left hand margin is now set. Space to the right to where you need your Right hand margin to bo. If stops before you want it to press the MAR. key press the space bar till the drsierd place press the R MAR key.
Jan 29, 2009 | Swintec 7040 Typewriter
MY SWINTEC 7040 WON'T RELEASE MARGIN.
Return to the L. mar. press and release the mar. rel. key, backspace to the place you want the margin press L. mar. key.
DickyO
Jan 16, 2009 | Swintec 7040 Typewriter
SWINTEC 8014 S TYPEWRITER
Press "MAR RELEASE", one key right of "MAR LEFT" in the upper left hand corner.
Press back space in the upper right corner until it's where you want it and press "MAR LEFT" to set it.
Tab over to where you want the right margin and press "MAR RIGHT"
Aug 05, 2008 | Office Equipment & Supplies
Swintec 7040 Typewriter Logo
491 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
