Question about Maytag EPIC MFW9700S Front Load Washer
Noise when the drum is spining it sounds like a jet taken off, its very loud . A little like its turning on a stone.. Any Clue what it could be?
    Novelist:
  • 77 Answers
That noise is a rear drum bearing. The parts alone will probably exceed $300. This is unfortunate news, but it's a problem that has plagued these washing machines. The labor to change out these parts, is going to be 2-3 hours unless u get someone who really, really, really knows these machines. So, multiply the local repair man's rate by 2-3 and add $200-$300 to it. I would recommend just buying a new one unfortunately and not even sink money into having someone look at it. Sorry for the bad news :(
Posted on May 29, 2010
Loud Jet Engine Noise
Erik? Do you either live next to an airport or on an approach pattern? Just wondering! No really...IF Your machine is making THAT much noise! Jeeze! You have a balance drum bearing gone! Maybe more. There are usually four of them located on the corners of the drum. They are throw away and buy new anywhere from $20-40 each. If you have no idea what I am talking about and your machine is over 7 yrs old. Get a new One!
Jan 16, 2014 | Washing Machines
I have a kenmore front load washer model 970-c42072. I'm experiencing a loud noise in the drum on the spin cycle even when it is empty no matter what setting (slow normal fast) What would be the...
If you turn the inner wash drum by hand, what kind of noise do you hear? If it is a thumping kind of noise, it would mean that the spider support arms are broken. If the noise is a loud rumbling sound, similar to a jet engine when it is spinning, it would mean that you have a bearing seal failure and the bearings need to be replaced. Either problem is a big job to fix since the entire washer needs to be taken apart. Get a few estimates before deciding whether it is worth fixing. Sorry.
Sep 01, 2010 | Kenmore 44072 Front Load Washer
When in fast spin there is a loud rattling sound as though there are stones in the drum
You could have something fast between the inner and outer drum, or one or more of the drum paddles is loose..
Remove lower rear panel of washer, remove the belt, and from the front spin the drum by hand, this this will show if the drum bearings are o/k.
There should be little or no noise from the drum.
If it is rumbling, or feels rough, then the main bearings have failed.
If ther is something caught, then you will hear it catching or clicking.
Hope this helps.
Dec 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Everything works great -until the spin cycle - loud noise
Have you checked to make sure all three shocks under the tub are ok?
Dec 18, 2008 | LG WM-2277HW Front Load Washer
When spining it makes very loud noise , like aeroplane when start
Hi.
It definately sounds like the drum bearings have failed.
It is a DIY job, but not easy, as it entails stripping the m/c down,
If it is under 5 years old, then it should be covered by a 5year warranty., you will just have to pay for the labour, certainly the cheapest option.
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
171 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
