Question about RTO Atwood Water Heater - 6 Gal LP
I have a atwood electric and lp hot water heater and its not calling for gas and dose not work on electric do i need to put other circit board in i have tryed every thing i can think of please help glenn
  • 553 Answers
With out actually looking at your water heater I can't tell for sure but your description suggest a bad thermostat or bad control board.
Posted on May 26, 2010
Atwood Hot Water heater wont' shut off
sounds like defective thermostat/gas valve
Aug 05, 2012 | RTO Atwood Water Heater - 6 Gal LP
We need to set water temp but can't find where to do it on the heater
The Atwood temperature adjustment is on the gas valve.
There is a metal lever sticking out.
http://waterheatertimer.org/gas-water-heater-timer.html#Atwood
Move the lever one direction, and if burner turns on, then move lever other direction to lower temperature.
If your gas valve is different, you might find answer on following page:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 08, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a gc6aa-10e hot water heater. I only get about 40 sec of hot water. I have raplaced check valve and put new thermostats in the water heater. I really dont know what else i should check. Need help...
Here is website for brochure and support center. http://www.atwoodmobile.com/water-heaters/atwood-water-heaters-brochure.asp
If it's electric it sounds like the elements.
Apr 23, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a atwood hot water heater GC6AA-10E its o...
Does yours have the little cut-out diode looking thing in the plastic jacket installed between power wire and thermostat? If yes, remove it from the circuit and connect female spade of wire, to male spade of thermostat,(just removing it to by-pass it) and try it now. Let me know what happens.
May 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
ATWOOD WATER HEATER
you will need to have a 115 curent for electric, run a line off the panel box, turn off water to the house drain it down, disconnect the lp gas line and cap it off, remove the water heater, install the new heater run the cold side water to the cold side {blue on the heater} the hot side to the red, take the cover plate off on the water heater run the wires, hook up the groung wire then the red and white wires to the wires comming off the panel box,, fill the water heater with water have a open faucet on the hot side, and bleed the air out, DO NOT TURN ON ELECTRIC TILL THE AIR IS OUT OF TANK AND WATER IS FLOWING THRU COMPLETELY, after you get water commming out of the faucet turn it off and turn the electric on to the water heater ,, wait about 30 min, you will have warm after an hour it will be hot and you are done,, good luck write me if you have questions, gary1121@aol.com
Jun 29, 2009 | RTO Atwood Water Heater - 6 Gal LP
I need a service manual for Atwood 2001 series RV LP gas detect
Call one of the motor home supplier and you will be able to get it.
Mar 30, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
151 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
