Question about Vacuums
I live in France and have a FV Favel vacuum cleaner the hose is broken, but can trace no manufacturer to fine a new one, there are no contact details on the instruction manual and I have failed to find any info on the net, can you help? The model No is SL227E
I have exactly the same problem - did you find a supplier?
Thanks
Posted on May 28, 2010
New Vacuum Hose
Contact any vacuum service and sales place or the manufacturer itself.
Oct 04, 2014 | Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Suction/Brush not working
Hi there SmartAlec from NelsonVacuums.com.au here.
There are a couple of common reasons that your electrolux vacuum cleaner would appear to have lost it's suction. The first and most common is that it has actually broken a belt. If the belt is broken the brushes won't spin and it will not pick up dirt. It is easy to test simply turn the vacuum on, release the handle (as if you were about to vacuum carpet) and lift up the head and see if the brushes are spinning. If not i can supply you with a new belt.
If the brushes are spinning then your next most likely cause is that there is a blockage in the vacuum somewhere. Test this by turning machine on and checking the suction at the hose (as if your were going to vacuum the couch) if it is poor then remove hose and fish out blockage. If it is ok you may have a blockage between hose and the brush of the vacuum.
If it is neither of these problems i can trouble shoot over the phone if you live in Australia 0269215200 or by email nelsonvacuums@netspace.net.au
Happy Vacuuming.. :)
Aug 25, 2009 | Electrolux EL5010A Bagged Upright Vacuum
My 4 yr old Nilfisk vacuum cleaner has been working fine up until now. But suddenly, it has hardly any suction power and also, hot air seems to be coming out thru the vents on top and also thru the space...
Hi there SmartAlec from Nelsonvacuums.com.au here.It sounds like a blockage of some kind. The best way to find it is to set the machine up for normal vacuuming and remove one component at a time until the suction returns. eg turn on and feel suction under floor head - not good? then remove the rod, then the hose.
Once at the machine on its own it gets a little triky as i don't know which model you have. However if you have a bagged model remove all the filters and the bag and retest. There will be at least 2 filters, one before the motor and one after (maybe under the vacuum or right at the back). If it is a bagless model even though the filter may look clean it is probably blocked with very fine dust. If suction returns when the filter is removed then you need to buy a new filter. I am a nilfisk vacuum cleaner agent so i can supply a filter for you.
If this still doesnt help you are welcome to call me if you live in australia my contact details are on my website www.nelsonvacuums.com.au.
Hope this helps !.
Happy vacuuming :)
Aug 23, 2009 | Vacuums
Dyson DC 11 Broken Wand Clip
Contact the manufacturer, thay should be able to assist.
Jan 05, 2009 | Vacuums
Replace vacuum hose
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797809
Generic problem for all Vacuums
Replace vacuum hose
Posted by bombertony on Jul 17, 2008
Replace vacuum hose
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You should contact the place where you purchased your vacuum, or if it is a big box store, you would need to supply us with the brand name, model # and the serial # for the vacuum and then you can contact your local vacuum cleaner dealer in your area or to contact the vacuum cleaner factory phone #, you can use the Google search site to locate the factory or manufacturer or re-send a message thru FixYa with the info and we will try to get you the information you needs to purchase a new hose.
Jul 17, 2008 | Vacuums
All terrain steam vac
Try and trace the hose back from the brushes to the pump. The hose could either be disconnected, kinked, or clogged.
Good luck - Tech101
Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hose connection broken.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552957
Posted by nualaheaneyi on Apr 28, 2008
If you have a broken hose connection, and not knowing the brand name of the vacuum, I can suggest 2 things. If you have an electric hose, meaning that it is attached to a electric power head or power nozzle, some can be repaired depending on what was wrong, but most of the time you have to replace the hose, some pigtails can be replaced but if the electric connection is broken, you need to replace the hose. If it is a non-electric hose, you can use a shrink tube, or cut out the broken part and use a hose cuff to join them together, so just shorten the hose and screw back on the original ends. In either case you need to check with a local vac dealer. Or you can make a new hose with new ends and leave the canister @ the bottom of the stairs and go up with just the long hose, unless you have an upright then you have to make it the length that is on the upright. Or replace it with the genuine hose from the factory or use the ends from the old hose on the replacement hose. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
