During a storm, electricity went off and when electricity came on again I lost the color on my tv
    President:
  • 1,099 Answers
This means absolutely no color - equivalent to a black and white picture. Not even a hint of color.
First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
Weak signal or defect in tuner/IF causing loss of signal strength.
Coler killer set too high (internal control) if it has one.
Defective part around the chroma chip/circuit. Faulty color oscillator.
Bad connections in area of chroma chip/circuit.
Defective chroma chip (don't suspect this first just because it is probably very expensive).
Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a .02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
Posted on Jun 01, 2010
TV Will not power on
HAVE YOU CHECKED PLUG AND INTERNAL FUSES
May 28, 2015 | Televison & Video
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
During a lightning storm Westinghouse 26
Change the input to some other you are sure works. Then if the problem persists, this might need attention by a qualified service technician.
Jul 24, 2012 | Westinghouse Electric Televison & Video
Don't know how to program TV since went off during storm I have a 37" TV purchased at Future Shop in March. Can't seem to reprogram it as it went off after a storm. Tried unplugging the...
Tries go into tv menu goto SETUP.Go down to Ch.enter pick AIR and enter to scanning.After finish scanning should have all the free DTV broacasting channels again.
Jun 10, 2011 | LG 37LG50 37 in. LCD HDTV
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
Power went out during electrical storm. tv never
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
Nov 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
My electricity went out during a storm. Now my
Yes its in the rear under the panel, I would look at the breakers in the electrical box first the dryer is on a circuit alone. The breaker could be thrown, it mite not look as it is just turn it off and then back to on.
Aug 09, 2009 | Dryers
Colors on screen distorted - depending on position of subject
you may have some magnetic particle in the tub area if you feel skill full open up shell and dust out should be restored also verify you do not have a speaker ontop of the tv speakers have magnets and are not shielded
May 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Onan 20K Generator runs constantly in stand by mode
Your remote start wires going into your transfer switch are closed, which means you transfer switch is the problem.
Feb 11, 2009 | Watts Onan Portable Generator - 4000 ,...
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
Electro Med Services...
