Question about Roper RT21AKXKQ Top Freezer Refrigerator
My 10 year old Roper fridge stpped keeping the fridge part cold but the freezer is working fine. Is it worth fixing?
    New Friend:
  • 24 Answers
Sure it's worth fixing, in fact you can probably do this yourself. This is usually caused by either a broken defrost heater, defrost thermostat, or defrost timer/control. Take all the food out of your freezer and remove any shelving that might be in the freezer. Remove the rear panel in the freezer and you'll see ice blocking the air ducts going into the refrigerator compartment. Use a hair dryer to carefully thaw ALL of the ice. Also check the defrost drain while you have it apart. The defrost drain is located in the freezer, in the middle. It's a small hole going out of the bottom middle of the freezer. Pour a coffee cup of hot water down the tube. If it drains, you're okay. If it puddles up, you have an ice blockage and you need to pour more hot water in the hole until it drains freely. Reassemble your freezer and if the problem comes back in a couple weeks or months, you know you have a bad part. Usually the defrost thermostat. It's a small round part that is about the size of a golf ball. It has 2 wires going to it. See if it's bulging.
Posted on May 26, 2010
SOURCE:
Refrigerator not getting cold enough
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 31, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
Noisy and fridge not cold
well i rember that guy??? that was when i had hair!!!!!!!!!!! sadly its gone now? along with my "get up and go" that got up and went!!!
your fridge,,, come on now,,its 10 years old,, dont you think you have had your moneys worth out of it yet?,,it needs a re-gas, pricy job that is, also maybe a thermostat as well,,,do yourself a faver dont spend money on it, its well past it,,bit like me now! save your cash and get a nice new fridge,,,just so you can show it off to all your palls,,, the old Dr who???happy days "A"?
May 05, 2010 | Fisher and Paykel Active Smart E522B...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Freezer works, fridge is warm
Your defrost timer seems to be bad. Find it at the bottom of the fridge and turn the knob to see if it activates. If it does then it is bad. If it doesn't activate then your element or thermosat is bad. These parts are not to expensive and you can do it yourself and save some big bucks. Be safe and disconnect power before servicing.
Jul 05, 2009 | Roper RT14DKX Top Freezer Refrigerator
Freezer fine- fridge temp is 51 degrees
I got the same problem. For some reason in the freezer part on the back wall there is a condensor and it keeps on getting all iced up and then there is not enough air pressure for the fan to circulate cold air to you fridge part. I took mine all apart used a hair dryer to thaw out everything which took out about 1 gallon of water from the hose in the bottom back of fridge. It fixed the problem for about 4 days and then froze up again, There must be some type of tempature sensor or automatic defroster not working like it shoud.Does anybody know? Help me too?
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
you may have defrost problem or check fan by compressor
Apr 04, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My freezer is frozen but my fridge isn't cold
I think there is a problem with your thermostat try replacing it.
Thanks.
Please vote....
Jul 24, 2008 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Side by Side Can't find model # Not cooling enough
I cleaned condenser coils with vacum, emptied the defrost tray and vacumed all the dust from the unit, unplugging first of course. Now it is working just fine. Thank you fixya for all your help and postings.
I still can't find the model number anyplace on the unit. This unit is only 2 1/2 year old but no model number to be found on the unit. But
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Roper RT21AKXKQ Top Freezer Refrigerator Logo
291 people viewed this question
Top Roper Refrigerators Experts
Steve Allison
Steve Allison
Bruce Denton
Gil Shultz
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
