Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore 77563 Installed last week and freezer defrosted all the food
Been installed for one week working fine, then freezer defrosted all the food must have been defrosting for 24 hours at least as most food completely thawed. Fridge working fine. Cannot see what is wrong after another 12 hours freezer "seems to be working again".
  • 1 more comment
  • Chefy Apr 07, 2008
    Also ice machine in top part of fridge stopped workign and defrosted
  • Chefy Apr 29, 2008
    thank you for your hlep - however I exported the Freezer therefore no warrenty - the freezer defrosted again last night 3 weeks after installation and seems to be working ok again today - however I cannot trust it as it has ruined food twice now
  • Anonymous Mar 28, 2014
    food in freezer has defrosted
  • 828 Answers
The refrigerator & freezer operate using the same system. One system. Your still covered by the warranty and I would suggest calling the installers or store from which it was purchased. The problem may be a faulty fan switch .
Posted on Apr 29, 2008
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Stale ice after a new water coil is installed
The water became stale inside copper lines feeding ice maker most likely. Dump your ice for a few times until this clears you should have ask for some money back for copper poison, (joking) Thanks,Sea Breeze
Feb 23, 2012 | Kenmore Refrigerators
Frigidaire White 16.5 cu. ft. Top Freezer Refrigerator (FRT17HB3)- The freezer works, the refridge portion is warm, it started last week ans seemed intermitten, we turned the cooling higher and it was fine...
All of your cooling coils on this model are located in the freezer. If you are cold enough in the freezer your problem is air flow to the fresh food section.
- There is fan behind the back wall of the freezer, be sure that is running.
- Look for frost build up on the back wall of the freezer, if present we have a defrost problem
- look for the duct or channels between the floor and freezer and top of the refrigerator they could be blocked with ice, if so we have a drain problem.
Let me know what you find and I will help you from there.
Apr 18, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore side by side 363.9562512 problems with defrost
you have defrost problem 1 heater 1 defrost thermostart or timer
Apr 07, 2009 | Kenmore Refrigerators
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
We have an RS21 fridge freezer. Always freezing up. Last week, under the newly announced extended warranty (seen on Watchdog) it was 'fixed' again with some new parts. Fine for a week BUT Today it has...
Time to check the defrost timer, these can go bad on defrost and warm up the freezer / or on run mode, and cause the freezer coils to frost up..it usually will cycle 2 or 3 times a day. If you can find the timer (bottom, near floor) it can be rotated to cycle. (there are about 5 wires connected to it (it's about the size of pack of cigarettes.)
Apr 21, 2008 | Refrigerators
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
Aug 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
395 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
