Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Ice maker leaks water
Whirlpool model #gr2shtxktoo. the container that holds the water for making ice islleaking. all i get is a slab of ice in te container that should hold ice cubes. do i need a new ice maker or can this leak be fixed?
    Novelist:
  • 77 Answers
Good work thus far. If the ice maker tray that holds the ice is leaking, you need to get a new ice maker. It would never work right if you tried to patch it, and would only cause further headaches. Sounds like you have a little experience which is good. Go down to a local retailer and purchase an ice maker and install it yourself instead of paying someone to do it ;) There is no foul in paying to get it done though. good luck!
Posted on May 30, 2010
Whirlpool ice maker just making thin slabs of ice
What is the model number of your refrigerator this problem is usually caused by inefficient water supply to the ice maker on a whirlpool icemaker the fill valve seals for 7.5 seconds if the water flow is obstructed T-valve that are not recommended for refrigerator water supply lines the next problem could be your water control valve or the filters are clogged restricting water flow here's a short video
Appliance 911 Sea Breeze
Dec 04, 2015 | Whirlpool Refrigerators
Layer of ice formed on the bottom of freezer and a layer of water with no obvious source has formed on the top shelf on the right side.
That is an easy one. Instead of the defrost liquid draining down the drain hole it is blocked and a slab of ice is forming. You must thaw out the ice box and clear the drain hole. Another thing that could cause this slab of ice could be a leaky ice maker water valve or a faulty ice maker pumping in too much liquid into the ice mold.
Jan 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker leaks water into holding container, frezzes up holdeing container, ice wont despence , because its froze
sounds like your ice maker has a degraded coating on the mold that forms the cubes. if you remove it from the freezer, then you can see if the coating is coming off. if so then you need to replace the ice maker.
Jan 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ge monogram ice maker makes loud churning noise. Any suggestions
Mine has been doing the same thing and foound it was the pump cavitating (dry). What caused it on my unit is there was buildup of minerals on the sides of the freezer plate so the ice slab wouldn't slide all of the way down onto the grid. When the unit would start the next cycle the water would ramp up over the stuck slab and down into the ice bin and then the pump would start making the noise. A related problem could be the cutter grid not heating so the slabs back up and results in the same issue. Look up into the freezer plate next time it makes the noise and see if there is a slab partially stuck.
Jun 12, 2009 | GE Monogram ZDI15C Automatic Icemaker
Maytag mff2557hew ice maker is leaking water and the water is freezing directly under ice maker in a huge glob
ice maker is leaking water and the water is freezing in holding tray causing a ice dam in container.
Jun 07, 2009 | Refrigerators
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
Whirlpool k40 ice maker... its been working fine then suddenly its hardly producing much ice, the cutting grid has been replaced and thats okay just very little ice. it goes through its process drops the...
Check the water hose. Is it kinked? Is the screen clogged. After a while minerals build up and could have clogged the intake making it hard to get the water necessary to make the ice,
Jul 01, 2008 | Whirlpool Refrigerators
Frozen slabs of ice instead of ice cubes
the icemaker could be leaking by can you see where the water is coming down into the bin from??
Jan 23, 2008 | GALAXY Microsystems 55622
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
233 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
