Question about Canon imageRUNNER 400S Copier
My cannon immage400s printer error e004 switch main off and on please solution me
The SSR has a short circuit.
1. the SSR has en error
2. the DC controller PCB has a fault.
Description
- the fixing heater remains on
- the fixing temperature has increased abnormally
Posted on May 29, 2010
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
Canon ir 400 error code e004
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
May 05, 2013 | Office Equipment & Supplies
How to remove error code (E000004-0010)from canon
Use this mode to clear an error code: E000, E001, E002, E003, E004,
E032, E717.
Using the Mode
1) Select <ERR> to highlight, and press the OK key.
2) Turn off and then on the main power switch.
Jan 05, 2013 | Canon imageRUNNER 5570 Copier
I keep getting error message E004-0002 ( Switch off and on again) everythime I switch on my canon clc 1000
E004 is a temperature related error. You would need to call in a service technician as it will require replacement parts.
Sep 12, 2011 | Canon CLC 1000 Color Copier
My canon IR 3100 CN displays an error code E000004-0001 plaese help me solve
E004
The main thermistor (TH1) has an open circuit or has poor contact. The sub thermistor (TH2) has an open circuit or
has poor contact. The thermal switch (TGP1) has an open circuit. The main heater (H1)/sub heater (H2) has an open
circuit. The AC driver PCB is faulty. The DC controller PCB is faulty.
E004 0001 protection circuit error of the fixing unit
Description: A short-circuit is detected in the triac (for 1 sec or more continuously) while the heater remains off (hardware detection) for 40 msec continuously.
Remedy: Turn off and then on the main power supply.
Remarks: fixing assembly triac malfunction/13V power supply error
Feb 04, 2011 | Canon imageRUNNER C3200 Color Printer
D861 E000 show up.. unplugged and reconnected still shows E000 Cannon Product
Hi there
E000000-0000
E000 to E004 are all to do with the fixing unit.
It can be reset.
It has been known to be caused by noise on the mains supply so a filter might keep it away.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again.
You should now be in service mode.
Select COPIER and this will give you some options along the top.
Select FUNCTION.In the list select CLEAR.
From the next list select ERROR and press ok.
Then switch off machine and back on at the power socket.
If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to turn the machine into a cabbage.
Sorry I cant help you more than this, hope it works for you
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Canon ImageClass D861 Printer
E004 error Canon 7301 Mfc
Here's a link to your support site.
Error E004 is:
Faulty fuser, replace Fixing Assembly(RG5-5559-000)
Hope this info helps.
Feb 11, 2010 | Canon 730i Laser Printer
Error Code E000 on Cannon Imagerunner 1600 Copier
Get into service mode by pressing.....
additional functions key (*) key and then...
ID(#) key...
Scroll down to PRINTER then press OK
Scroll down to PRINTER RESET
then indicate YES(*)
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Any problems please get back to me
Thank You
Mar 21, 2008 | Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
93 people viewed this question
old marine
old marine
