Question about Philips Philishave HQ5812 Electric Shaver
Hq101 cleaning fluid difficult to find. What can be used instead?
  • Philips Master
  • 1,610 Answers
Philips item HQ200 can be used as a suitable substitute. It can be purchased at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-hq200-smart-touch-jet-clean-solution-p-258.html
Posted on Jun 04, 2010
Difficult to shift from Park to Reverse and back. All other gears move fine between each other. Brakes switch works fine. Transmission fluid is fine.
The linkage needs ajust. Its under the vehicle so if u du it..use jackstands...a jack alone will fall. A shop manual is helpful..library or from partstor. U cud also have a worn trans
May 30, 2015 | 2000 Honda Accord
ERROR e 014
You'll need to remove the fuser from the copier and inspect it to see if it is binding up making it difficult for the fuser drive motor to turn it. Lubricate any gears thet are gummed up and not turning well. Pay special attention to the swing plate assy. Also check for frozen bearings,flat spots on lower fuser roller, or anything else that can restrict fuser movement.
If that doesn't fix it - you may need a new motor - but that is almost never the case. the swing plate on the front to the fuser has the input drive gears on it,,, the shafts/gears get gummed up making the fuser very hard to turn, causing the E014 you described. Pull it apart, clean and lube the gear pivots. I use automatic transmission fluid instead of oil,, it never gums up!
Apr 08, 2014 | Canon imageRUNNER 400S Copier
Dirty door seal
You can first try cleaning out the drum of your machine. Run it without anything in it, using 1/2 gallon of Vinegar instead of soap. Hot water will work best. Most hardware stores, or bestbuy,sears,etc. Have packets of cleaning agents you can use instead of the vinegar. You can also use brake fluid for cars on a rag and wipe down the door seal to clean it, then run it through a whites cycle to remove any leftover residue.
Hope this helps!
Dec 17, 2013 | Washing Machines
Wiper reservoir filled with oil instead of windshield fluid
Sometimes they have those reservoirs recessed so far under stuff it is difficult to get to. Don't give up, though. There is always a way, and they are removable. Some are pulled off from the bottom. Some are placed behind a shield in the front wheel well. Usually only a couple of screws retain it. Pull the hose off, the motor connector, unfasten the screws and it should be free to come out.
Jul 17, 2012 | 2003 Mercury Grand Marquis
I am trying to change the transmission fluid in my 2004 Chevy Trailblazer.
This tranny has approximately 13 quarts of fluid. Just dropping the pan and replacing the filter will yield about 5 quarts or so, with the balance still sitting in the torque converter. I recommend just doing this instead of paying someone to power flush the system. There are debates whether or not this method will damage the tranny. When I did it, I got around 6-7 quarts out of it. Use GM's new transmission fluid Dextron VI. It's much better than the old stuff. GM starting putting the Dextron VI in 2009 and newer vehicles. Make sure you know what size your pan is, there is a shallow pan and a deep pan, the deep will have a step in it, the shallow will be completely flat.
There is another way to get rid of all the fluid, but it's very time consuming and difficult if you've never done one before. Involves disconnecting the transmission fluid cooler line at the radiator and having the pump inside the tranny pump out all the fluid for you.
Dec 21, 2010 | 2004 Chevrolet TrailBlazer
Where is the power steering reservoir located on the 1990 Toyota Carolla?
Make sure that your vehicle is parked on a level surface and the engine is cool before you check fluid levels. Power steering fluid and other fluids read at different levels when warm instead of cool. Locate the power steering fluid reservoir. It is located under the hood of your Toyota Corolla on the passenger side next to the engine. The reservoir is connected to the power steering pump. Remove the cap and use the dipstick to check the fluid level. For the most accurate reading, clean off the dipstick with a rag first, then re-insert and remove for the fresh reading. Add automatic transmission fluid or power steering fluid approved for use in Toyota vehicles if the fluid is below the low level mark. Add fluid gradually to keep for over filling the reservoir.
this will help.thanks.
Feb 20, 2010 | 1990 Toyota Corolla
2001 Passport with automatic has no dipstick for transmission, how do I check level and where do I add fluid
If you are looking to check the fluid levels and add transmission fluid you will need to first purchase a fluid pump at your local car repair store. Most run between $10 and 25$. For best results, run your car for a few minutes to bring the fluids to operating temperatures before attempting to add fluid. Be careful of hot surfaces and liquids.
It is difficult to check the level of fluid in the 2001 Honda passport because it lacks a dipstick. Instead, you will have to get underneath the car and check it at the Automatic Transmission fluid pan. This is located approximately below the center of the rear passengers seat on the underside of the car.
To check the fluid, remove the top most bolt on the automatic transmission fluid pan (most use a 3/4 inch socket). Use your finger or other object to see if the fluid level is at the same level as the drain plug. This can be difficult to do therefore it may be easier to add fluid until it is full to verify that you are at the correct levels.
To add fluid, remove the top most bolt on the automatic transmission fluid pan (most use a 3/4 inch socket). Using the fluid pump, slowly add transmission fluid until it starts to drip out. Replace the bolt. Take care not to over tighten the bolt.
If you want to be thorough, start your car and while your foot is on the brake, run your transmission through the gears slowly. Turn off your car. Remove the fill bolt and check the fluid level again. If it is not full see the previous steps. If your levels are OK, replace the bolt and you are good to go.
Jan 20, 2010 | 2001 Honda Passport
I started hearing a grinding noise when I turned the wheel and I thought I might just be able to add some power steering fluid but it looks like I can't do that what is your suggestion because now it is...
VW uses hydraulic oil (VW part # G 002 000) and not ATF. Your reservoir is located beside the battery, use a flathead screw driver to remove the cap/dipstick. Always clean dipstick with a clean rag before using as a measuring device.
COLD: The level should be +/- 2mm of the minimum mark. Adjust the fluid level if required and screw the cap back on hand tight when done.
HOT: With the engine running, temp should be above 50*C (122*F). The level should be between the Max and Min marker. Adjust the fluid and screw the top on hand tight when done.
Only use VW part # 002 000 Hydraulic OIL and not ATF
Aug 11, 2009 | 1999 Volkswagen Beetle
My floormate isn't picking up the wet water
Check the uptake tube. When you push the release button and bend the top of the unit towards you, you can see the tube coming out of the floor assembly. Mine split right there.
Jul 10, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover F5858-910 doesn't spray water
Hello dc42 & osuguy101. I suggest using a cleaning solution, 50/50 vinager/water, in the fluid tank to clean the ports. #2 Unit may have a fluid pump problem. Please update me on results.
Sep 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Philips Philishave HQ5812 Electric Shaver Logo
647 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
