Question about DeLonghi Pinguino PAC-77E Air Conditioner
Air conditioner delonghi will not cool the room down
THE RED LIGHT IS ON AND WILL NOT START?
Posted on Jun 29, 2010
My DeLonghi PAC A110L portable air conditioner is leaking water. How do I fix this?
Hallo
If an Air Conditioner is on cooling then the Air Conditioner also removes humidity from the air any Split Unit, Window Wall A/C you name it... Any A/C on cooling dehumidify the air in the room.
To decrease the volume of the water:
1) Clean Air filter/s
2) Keep doors and windows close( can open now and again).
I don't know how that portable A/C of your look like but I believe theirs a water pan inside that needs cleaning I think it's full.( best is to service the hole A/C).
Hope this was useful.
Regards
Jun 09, 2016 | DeLonghi Heating & Cooling
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
Fan comes on; however, can't get the desired temperature to set. I select it and two seconds later it shows a higher temperature.
Hi Kate, When you press the button for your desired temperatre setting it will show this temp' say 17*c for a few seconds then it will revert back to showing the actual room temp' say 23*c, it should then cool the room down to what you set it at. hope this helps.
Sep 03, 2013 | DeLonghi CF210 Portable Air Conditioner
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
Delonghi pacl90. Lost manual, don't know what setting is best for cooling my house. I have a small 850 sq ft place. Should 1 side be blowing out hot air, and the other side have cool air?
Unfortunately, I don't think you're going to be able to find a setting to best cool your house. The model that you have, is a room air conditioner that only generates 10,000 BTU's and is only rated for up to 400 square feet. That's about half the square footage of your house. It simply will not cool your entire house.
To make the most of what you have, place the unit in a room where you spend the most time. Close the door to that room and only air condition it. To keep the other areas a little more comfortable, close the drapes or blinds during the hottest periods of the day. If you have a ceiling fan in that area of the house, run it a fast as you can comfortably stand, in a clockwise rotation. Generating a wind chill in the area that's not air conditioned will help make it more tolerable.
I hope I was of help to you. Thanks for choosing fixture.
Jul 24, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Room at 84. unit set at 65. outside is 94 degrees.
I brows the web to see the specs of your unit.In that case the unit cannot cool down the room temperature, you must consider the following:The volune of the room, it might be exceeded the specified capacity, the thermal isolation of the room, must be shield from leaks,and the materials used,the absorption of the matterial at first operation, the materials around the area will absorb coolness prior to room air, and the ambient temperature outside may affect the performance of the system,If too hot outside put a better thermal isolation inside.that helps? need thumbs up... sams_Ew0rks**
Sep 02, 2009 | DeLonghi CF210 Portable Air Conditioner
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Pinguino pac-166 not cooling enough
CHECK AND CLEAN THE DUST FIELTER AND ALSO CHECK THE BLOWER THEN TRY IT
Jul 06, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguino PAC-77E Air Conditioner Logo
456 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
