Cartridge error first I try change the cartridge with NO ORIGINAL, but now i buy a new original cartridge, i turn on the printer and get this message: incompatibility cartridge
    Sergeant:
  • 284 Answers
Please provide more relevant details for printer brand, model and cartridges.
Posted on May 26, 2010
CARTRIDGE ERROR
If it is new, return it for warranty, should be changed for a new one. If warranty has expired, there's nothing to do by dispose it and buy a new one. The printer cartrige, as simple as it may look, is a very complex electronic disposable device.
Apr 10, 2015 | Office Equipment & Supplies
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
My canon MP 145 printer displayed E5. How can I solve my problem?
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 20, 2011 | Computers & Internet
I have an HP Photosmart C4795 printer. I am getting an error "cartridge error:. I have tried changing to new original HP ink cartridge and loading and unloading cartridge several times. I can not...
Welcome to FixYa!
Try to reset the printer by doing the following;
1. Turn ON the printer.
2. Disconnect the USB printer cable at the back of your printer while the printer is ON.
3. Remove the cartridge.
4. Wait for the "Insert Cartridges" message to display on the message screen of the printer.
(You can skip this if your printer does not have this feature.)
5. Disconnect the power cord from the back of the printer.
6. Wait for 1 minute.
7. Reconnect the power cord.
8. If the printer does not turn on, use the power button to turn it on.
9. Reinsert the cartridges.
10. If the printer prompts you to print a calibration page or requests for a cartridge alignment, please do so.
11. Reconnect back the USB printer cable and try to print.
I hope that this would be helpful to you, thank you for usng FixYa!
Jas247
Mar 07, 2011 | HP Photosmart D5145 Printer
Cartridge error
Hi,i once had the same problem with my machine,I was able to fix the error message of check cartridge, using cotton swab with rubbing alcohal, clean the 2 cartridge holders including the back part. chance are you will see black all over your q tip. continue to clean everthing. then buy 2 new cartrdiges that are not refills and it should work. the only thing is since the cartridge has expiration dates this cause a problem for the printer for some strange reason. my machine is working fine now
Thanks and good luck
Jun 08, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Error message "Cover Open"
try to put back the old cartridge if the message disappear ,means the new cartridge have problem. may be you buy a remanufacture one.
Dec 10, 2008 | Office Equipment & Supplies
Installed a new refilled PG-5BK ink cartridge into an MP530 printer and get the error message 1681.
Thats because of usingthe refilled cartridge. Most printers these days have a sensor to detect the use of refilled cartridges, or even generic (3rd party) ones. They do this to prevent customers from buying cheaper 3rd party cartridges. Its kind of unfair business practice, but what to do?
Use an original, new cartridge, and this error will go.
Nov 01, 2008 | Office Equipment & Supplies
Dell 926 printer
Dell cartridge are quite expensive, and refilled and non original cartridge are often not accepted by Dell printer. If you use non original cartridge often you keep getting this message unless you replace both cartridges.
Be also careful also if you use refilled, sometimes refilled can leak all over the inside of your Dell printer right when ink is coming to the end.
In your case try replacing both cartriges at the time, this usually clears the error.
A suggestion: Dell small inkjets are sold at a price often inferior to the cartridge set price, and now you know why, ask the price for a new Lexmark, HP, Epson,Brother, Canon etc. next time you have to replace a cartridge set, it may be worth buying a new printer.
Apart small inkjet sector, Dell produces excellent laser printers, computers, laptops and more.
You can read more opinions on small dell inkjets here or using google.
Aug 18, 2008 | Office Equipment & Supplies
DELLA 940 DOES NOT PRINT
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jul 20, 2008 | Dell A940 All-In-One InkJet Printer
21 people viewed this question
jasbo
jasbo
