Question about GE AJCQ08ACB Air Conditioner
Slings water out of the top where is drain on
Slings water out of the top where is drain on unit
  • 391 Answers
The drain is in the rear of the air conditioner (outsid) so make sure the unit is tilted a few degrees toward the outside coil so that the collected water can be slung on the outdoor coil to make it more efficient as it should be.
Posted on May 27, 2010
Leaks water from an open tube at the bottom center of the back of the unit.
if your talking about a window unit it uses water that would normally drain out and slings it over condensor if it gets to a certain depth the hole would allow it to drain out.
Aug 01, 2015 | Heating & Cooling
Brand new kenmore air conditioner 18500 btu, there is no place for the water to drain, no drain plug? water is getting high... model 70181
The new Room A/C's do not have drains as it uses the condisation from the pan to help cool the coils this makes the unit more effecient.
Sep 01, 2011 | Kenmore Room Air Conditioner
My new frigidaire window unit air conditioner makes a constant "water gurgling" noise after it's been running for an hour or so. The tilt is correct - have I missed a plugged drain?
Hello, some window units will not have a drain plug on the bottum, instead they use the condenser fan to sling water on the condenser to evaporate the condensate. The gurgling is normal when humidity is high and alot of condensate builds up.
Jul 19, 2011 | Heating & Cooling
Where is the drain hole on my frederich quietmaster wall air conditioner?
Hello, if there is no drain hole under the unit then it uses the fan blade to sling water on the condenser to evaporate the condensate. Some window units are made this way instaed of using a drain hole.
Jul 12, 2011 | Friedrich QuietMaster KM24L30 Wall/Window...
I have a AW06ECB Window Air Conditioner Unit that is not draining water. It is holding it in the bottom pan. I don't see a drain pipe or hole on the bottom of this unit for it to drain either. Any...
Hello, most window units will not have a drain to remove the condensate. Instead they use the fan blade to sling the condesnate on the condenser and since the condenser is warm/hot it will evaporate it. Also, when the humidity is elevated there will be more water at the bottum of the drain pan.
Jul 10, 2011 | Samsung AW0507M Air Conditioner
Where is the drain hole on my haier air conditioner located
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
Jun 05, 2011 | Haier Heating & Cooling
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Water is not draining forom my hampton bay air condiotioner. It is gurgling and you can see water inside the unit. I have tilted it more in the window there is some water dripping but there is still water...
Allot of Window units do not have a drain anymore. The condenser fan picks up the water that lays in the bottom of the unit and slings it against the condenser coil to help keep it cool. If it is not leaking water inside the house it is normal to have some water in the bottom of the unit. This is verified by not having a drain hole or hose. As an A/C service tech I didn't care for this design as allot of people thought that there was a problem when there was not. They also tend to be a little noisier as the water makes noise when it is being thrown around inside the unit. I hope this helps
Jul 06, 2010 | Heating & Cooling
Air conditioner is emitting condensation through top of unit
The manual said to remove the rubber cap on the back, exterior, of the unit, insert the drain plug and push down lightly to drain off the excess water accumulation. However, a drain plug was not included in the package. Furthermore, there wasn't an actual "hole" in the unit to insert it. I did drain what I could by just leaving the cap off. This did not take care of the problem completely. Next, I unscrewed and removed the the front, interior, of the housing unit. I then noticed additional water buildup in the bottom of the unit under the sling fan. I could not remove the fan, so I used a turkey baster to **** out what water I could. I know - resourceful don't cha think! Then pushed paper towels into the bottom of the cavity to absorb any leftover water. Whaaala - problem solved.
Thanks for your prompt response.
Teresa Wellman
Jul 13, 2008 | Goldstar Heating & Cooling
Is there a drainage plug or hose on the air conditioner? It's leaking.
To increase the efficiency of the air conditioner's cooling to meet US energy requirements, most manufacturers eliminated the traditional drain plug. Instead, they switched to a design that used the extracted moisture from the room to help evaporatively cool the condenser.
To do this, the traditional fan blade was replaced with a 'sling blade' which was a fan blade with a rim or ring around it. The drain plug or drain hole in the bottom of the pan was eliminated and replaced with overflow notches in the back edge. Along with a solid piece drain pan, this provided a pool of water for the edge of the sling blade to dip into and pick up water to 'sling' or spray around the compartment to create evaporative cooling. The overflow notches established the maximum depth of the water pool and are also the lowest place when installed properly.
Although this is more efficient, this has caused 2 problems: increased noise as the water is slung around and water spray from the side air vents.
Persons have drilled holes through the pan or back edge as drains. This is not recommended as it negatively effects the colling ability of the unit and could lead to a voided warranty or premature failure.
Instead, insure that there is adequate pitch with the installation and make sure the overflow notches are kept clear.
If you 'need' a drain hose, my suggestion would be to drill into drain pan's back edge or the rear potions of the sides. The hole should be at the same level as the overflow notches. Once the drain hose is installed, block/cover the overflow notches to redirect the excess water to the drain hose instead.
Jul 07, 2008 | Samsung AW0603B Air Conditioner
GE AJCQ08ACB Air Conditioner Logo
149 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
