Question about Canon PIXMA MP530 All-In-One InkJet Printer
Says paper jam; no paper in printer anywhere
It says to press ok, when you do it doesn't acknowledge it.
  • 973 Answers
Did you put paper back in there and then press OK?
Posted on May 26, 2010
    Sergeant:
  • 284 Answers
Pls provide more details, likes blinking how many times, error code?
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    Erreur 5100
    According to your problem it is a carriage error, meaning something was jamming the cartridge carriage at some point. Check first if stuck paper anywhere clear it and then try to reset the printer.
    You can try to reset it to factory mode by following the steps below:
    Turn off the printer.
    Press and hold the ON button while pressing the Stop button.
    When the Power LED lights in green, while holding the ON button, release the Stop button.
    While holding the ON button, press the Stop button 2 times, and then release both the ON and Stop buttons.
    The printers turns into a kind of factory mode, wait for about 10 seconds, until it says "Idle"
    Press the ">" (next to the "OK" button) once.
    Press the "OK" button.
    Press "OK" again for "Without cleaning"
    then try to print.
    If it doesn
    Mar 29, 2011 | Canon PIXMA MP600 all-In-One InkJet...
    There is a paper jam error message
    Sometimes thr formatterboard might be responsible for this,but you can open the printer and make sure all sencors are not coverd with dust nor pieces of papers,if problems pesist try replacing the board.
    Apr 14, 2010 | HP OfficeJet 6210 All-In-One InkJet...
    Canon MX860 Rear Paper Jam
    I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
    Jun 27, 2009 | Canon Office Equipment & Supplies
    HP Photosmart 2610 - Paper Jam
    I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
    Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
    Paper Jam
    Most likely a bad or obstructed sensor. Use compressed air to blow around the top and back of the printer removing heavy paper dust and look under the pickup rollers for small pieces of ripped paper. If the sensor is bad, contact service and support.
    Jul 29, 2008 | Canon PIXMA MP460 All-In-One InkJet...
    LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
    A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
    Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Canon PIXMA  MP530 All-In-One InkJet Printer Logo
    166 people viewed this question
    old marine
    old marine
