Question about Canon i450 - Printer - color - ink-jet - Legal, A4 - 600 dpi x 600 dpi - up to 18 ppm (mono) / up to... InkJet
It won't print anything in color
My Canon i450 won't print anything in color. I put in a new color cartridge and tried rebooting the printer. So far it still does not print color.
    Sergeant:
  • 284 Answers
This is an old days printer. The print head is almost reach to the end of life. Most probably is the print head faulty.
Posted on May 26, 2010
Canon IP3300 won't print color
hi chette,
its a common problem for printer dye ink,have you try to use other cartridge? a brand new one maybe?
if you insist using the old one, try these step.
1. use vinegar to clean your cartridge head
2. put a little vinegar into the cartridge
3. try deep cleaning it.
it only work for dye ink base not else :D
ciaw.
Jul 11, 2012 | Canon PIXMA iP3300 Printer
Won't print because color is out, I have setting on black only shouldn't that work?
i think all printers do not print if one of the separate color cartridges is empty. check ink and replace. hope this will help.
Apr 02, 2012 | Canon PIXMA MX310 All-In-One Printer
Colored refill ink cannot be recognized
It is called e5 error.
For Canon cartridges, after 4~5 refills, the color cartridge cannot be recognized by printer.
In this case...there is no solution so far...just replace with new cartridge.. that's it.
(To avoid e5 error, you need to make sure "plug out" the power, before take out your cartridge for refill. Yes... "plug out" the power cords!!!!
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 06, 2011 | Canon PIXMA iP1300 Printer
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
Jul 17, 2009 | Canon PIXMA MP470 All-in-One Printer
Replaced cartridges
keep cleaning untill it starts to print clearly, you may reuse the same paper for that purpose, if you don't see any progress after 10 cleans, consider getting lasser printers, they are immune to print head drying and save alot of money on ink replacements. go with brother color or black and white series. I switched and don't have problems anymore
May 20, 2009 | Canon i450 - Printer - color - ink-jet -...
Canon i450 uneven printing
The problem could be as simple as your paper not going through the tray straight, or just aligning the print cartridges. Make sure when your paper is pulled through the printer that it isn't getting pulled more quickly on one side than the other. Also, go into your printer control panel to find the 'alignment option' and follow the steps to complete a proper alignment. If that doesn't work, get back to me with more details about the problem. (is it on a slant, are half the sentences printing on a different angle etc.)
Apr 16, 2009 | Canon i450 - Printer - color - ink-jet -...
I 450 printer sends command to print but, no print on paper, paper goes through the printer as tho' it is printing but no print
Check your ink cartridges. Even with ink inside, the heads could dry up and not allow new ink to penetrate. Take a dry cloth (rag, not something you wouldn't want stained) and gently wipe it over where the ink shoots out of the cartridge. If you barely get a streak on the cloth, try dampening up the cloth and gently wiping the ink cartridge to see if it loosens up the ink flow.
If there is already plenty of fresh ink coming out of the cartridge, you might have a problem that isn't worth fixing. Repair costs compared to buying new are very similar these days.
Apr 01, 2009 | Canon i450 - Printer - color - ink-jet -...
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
Canon i450 Printing issue
this clearly indicates that the printhead of your black cartridge is completely blocked and it needs internal cleaning which cannot be done by printers cleaning commands.the print head has to be removed from the printer and and then cleaned with isoprophyll and soft tissue very slowly and gently.if u dont have a technical idea taking it to the repair center is advisable.
hope this helps.....
thanks.
Nov 03, 2008 | Canon i450 - Printer - color - ink-jet -...
Canon i450 - Printer - color - ink-jet - Legal, A4 - 600 dpi x 600 dpi - up to 18 ppm (mono) / up to... InkJet Logo
126 people viewed this question
old marine
old marine
