Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Bearings on Hotpoint
My washing machine suddenly very noisy on spin and also have spots of oil on white washin, reading your problems am guessing bearings have gone on drum - is it worth trying to repair or shall i get new machine
  • 57 Answers
I WOULD GET A NEW SET OF BEARINGS IN THIS MACHINE BECAUSE THESE ARE VERY RELIABLE AND I HAVE DONE LOADS OF THEM AND ALL YOU HAVE TO DO IS SHOP AROUND FOR A GOOD SERVICE MAN AT A FAIR PRICE
Posted on Jul 15, 2008
What can cause noisy spin on wd960 hotpoint ?
bad bearings, seal leak let water in bearings
Tub seal leaking letting water get to tub bearings need shaft and bearings replaced. takes special tools
Aug 31, 2014 | Hotpoint Washing Machines
Grease /oil spots on clothes coming from washer
This sounds like the drum bearings are starting to wear and allowing grease to infiltrate through the inner seal.Does it sound noisy on the spin cycle.
May 03, 2010 | Speed Queen AWN432 Washer
Very noisy when Hotpoint Aquarius WMA46 is on spin
It is the main drum bearings that is causing the noise.
There is no provision made for lubrication.
It can be done as a DIY fix, but it is a very involved repair, as it means having to remove the whole inner workings of the washer,
Not a task I would recommend unless you know what you are doing, and feel competent to tackle it.
Good luck.
Dec 05, 2009 | Hotpoint Washing Machines
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarious 1200 IE When spinning the drum ocsillates violently and is very noisy.
Remove drive belt, and spin drum by hand, if noisy or rough, then bearings have failed, if no noise, then could be suspensioon leg problem.
Please rate my solution.
Tghanks.
Sep 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
http://www.candmdomesticappliances.co.uk/section.php/88/1/hotpoint-washing-machine-spare-parts
Apr 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
the unit is only 18 nmohths old then what you need to do is contact the manufacture and explain to them what is happening and if they are having simuary isssues with that particular moidel number. Possibly they are and you may be able to have it repaired on their dime! 18 months is not that long for a washer to start having these problems if you have not abused the unit by overloading the washer or over filling it with soap. Good Luck
Jan 05, 2009 | Hoover AAA160 Front Load Washer
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
151 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
