Question about Toshiba Satellite A200-0ET00X Notebook
My screen on my satellite has gone completely blank. Computer turns on but screen remains blank.
  • Toshiba Master
  • 4,806 Answers
This could be a problem with the LCD inverter, GPU (graphics processing unit), memory or it could even be related to the battery.
First of all turn the laptop off and remove the battery. Then turn the laptop on just using the AC power only see if that resolves the issue.
If not then remove the system memory which you should find in a compartment underneath the laptop (you will need a philips screwdriver for that) clean the brass contacts and the slots that the memory clips into and then put the memory back in and try to boot the laptop up.
If that does not work get an external monitor and connect it to the laptop. Use the keyboard toggle to switch screens, its usually Fn and one of the F keys (between F4 and F7 usually)
If the monitor comes on and shows the boot information then you are looking at a new inverter or re-solder the old one.
If the external screen doesn't come on then the problem could be faulty memory or a down GPU.
If you need anymore help on this matter please post back.
Good luck and regards.
Posted on May 26, 2010
Toshiba Portege r200 was working normal (up until yesterday). Today, when I first turned it on, the fan was on and it sounded full blast, but screen remained dark (blank). I held power button until it shut...
The part that supplies the power to the screen is gone. I recall is is called the 'exciter'. They can be replaced, so take it to a computer repair shop. Same thing happened to my Toshiba.
Aug 18, 2017 | Toshiba Portege R200 Notebook
Screen will remain blank after mac is turned on sporadically.
the only place i know they fix this is london (shop name micromend ) had the same it is a common fault graphics chip fault
Jun 01, 2009 | Apple 15.4 MacBook Pro Intel Core 2 Duo...
Monitor is blank when we turn the computer on.
Maybe not. Find the FN key. It is usually BLUE in color
Then look on TOP row of Computer keyb (or all over) and find CRT/LCD.
Press the FN and that key and your screen should come back. You accidentally sw. it to CRT (outside, external monitor)
Jan 14, 2009 | IBM ThinkPad T23 2647 Notebook
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Cannot wake up the screen
do u have a system reset on the back of the unit if so press ahd hold for 30 seconds and tru to reboot
s
Aug 22, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A75-S206 PC Problem
if your screen remains blank after power on, then its not virus problem. The POST information like CPU speed memory check, HDD details etc, should must appear on screen. If not then the problem might be on board and/or on your screen.
You should take a tour to service centre. If its in warrenty, it will be free of charge.
Thanks
Iqbal
Jun 19, 2008 | Toshiba Satellite A75-S206 Notebook
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
Laptop Screen is Blank
there is a hole on the back usually goldish inside take a pen push it in there hold for a couple seconds and press the power button
Jan 26, 2008 | Toshiba Satellite M35X-S349 Notebook
Toshiba Satellite A200-0ET00X Notebook Logo
328 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
