Question about LG Microwave Ovens
I'm want to check fuse I have LG microwave model # LMV163088 march 2006
  • LG Master
  • 9,098 Answers
That may be LMV1630B?
If so, you can download the service manual here.
To order Goldstar / L.G. parts, visit Encompass. You'll probably have to call them at 866-779-5835.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Posted on May 28, 2010
How to remove LG microwave to check fuse? Model LMV1813ST Serial: 102TRXT01402
The service manual for your model is here. That and my video here will give you disassembly info.
More questions? Contact me directly here.*
* always include the full model number and FCC ID number from the label on / in your microwave
Jan 28, 2018 | LG Microwave Ovens
Lg microwave fuse location
Fuses are normally internal on Microwaves and opening the cabinet exposes dangerous voltages, even when disconnected.
The fuses used are 'Ceramic' and look like this.
ceramicfuse-3tkv02zfhnnile0ve5y4fcys-1-0.jpg However, just replacing it may not fix the problem, if you have a shorted component inside, it will need to be repaired by a competent shop/technician.
May 15, 2017 | LG Microwave Ovens
LG under cabinet microwave (LMV2073ST) overheated. Now no power to unit.
There may be a fuse inside.
Always put a microwave back together to test it. A mobile telephone in the vicinity will also check a microwave for leaks.
Feb 14, 2015 | LG LMV2073ST Stainless Steel 1100 Watts...
My LG microwave oven 3850w4a043b is working but not heating up?
Check the microwave fuse. It is in a plastic fuse casing on a wire. The fuse is about 1/8 dia x 2inch. Be sure to replace it with exactly the same rating.
Jan 15, 2014 | LG Microwave Ovens
How to change fuse for lg lrm1250W
Hello
Get beneath the LG microwave, and grasp it on the bottom at either end. Lift the microwave up slightly, and pull it out from the wall to remove it from the mounting plate.
Turn the microwave onto its face on a soft rug or blanket. Remove the screws from the back panel of the microwave, and slide the panel upward to take it off the unit.
Look for the three fuses in the LG microwave -- one at the lower-right corner, one in the upper-right corner and one in the top center. Check each of the fuses to see if any of them look dark in color; this indicates a burned-out fuse.
Remove the burned-out fuse by gripping it firmly and pulling it away from the wall of the microwave. Once the fuse is removed, press the new fuse into the same position in the microwave until it clicks into place.
Slide the back panel onto the microwave, and replace the screws. Lift the microwave into the space beneath the cabinet from which it was removed, holding it slightly higher than the mounting plate, and lower the microwave until it catches on the mounting plate.
Oct 05, 2011 | LG LRM1250 Microwave Oven
My LG microwave went completely dead. I is only 3
under the outer cover,its either a 10-15-or 20 amp ceramic safety fuse avail at most hardware stores, the amp rating is on the side of the fuse, if the new one blows then either the H.V. diode/capacitor or the magnetron can be suspects
Oct 03, 2009 | LG LMV1630ST Microwave Oven
My microwave was made in march 1984. the serial numbers have been rubbed off on the door. the fan & lights etc work but it won't heat up...what can i do?
HI! the magnetron on your microwave is not working, first thing that you should is check for the fuse or the thermal cut off.
Sep 23, 2009 | Microwave Ovens
THERE ARE NO HEAT WHEN I START MY MICROWAVE ALL
Hi! it seems that your microwave oven, magnetron is not working, check the fuse.
Sep 12, 2009 | Microwave Ovens
Does not heat up
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 01, 2009 | LG Microwave Ovens
Microwave Ovens Logo
99 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
