Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv goes blank, sound stays on
My tv goes to blank/black screen but the sound remains on. i shut it down
and sometimes it comes back on for a while then cycles back to blank/black screen w/ only sound being on. i had the motherboard replaced a year ago and its out of warranty. any help would be great,
should i take it to the repair shop or just junk it
  • Anonymous Mar 23, 2014
    i was watching sport and switched off the tv to go shopping when I returned I switched the tv on and the screen remained blank
I had an older hitachi. Same problem. It was the capacitors in the comb filter had dried out. Replaced them and it was like brand new.
Posted on Apr 08, 2008
SOURCE:
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
My laptop worked fine on night then in the morning i started having problems. These are the problem that i am having my with my HP Pavillion 6910us Laptop. 1. My laptop comes on but cuts off after 5 to 6...
Hi
At some point if you can get the computer to stay up for a while, you should go into control panel and check your
POWER settings. The other thing you should try if you haven't already is to shut the computer off and pull out the battery. Then after a minute re-install the battery and see
if that helps.
Good Luck
Joe
ps: If I come up with any ideas I will post.
Mar 04, 2017 | HP Pavilion Dv6910us Notebook
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Freezing then blank screen
you have a loose connection, good luck....
Jan 08, 2008 | Samsung X15 Notebook
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
179 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
