Question about E-Machines eMachines Monitor E15T4
Monitor cuts off
After 5 minutes monitor shuts off and i have to keep turning it on.
This could be the result of a few different things. If you haven't checked, click start, control panel, performance and maintenance, and power options. In this box, there should be numerous setting possibly pertaining to your specific problem. Also, ensure your cpu fan is running. A failed cpu fan will make your monitor turn off. Additionally you will have to make sure your power supply isn't bad. The easy fix is the first of the issues though.
Posted on May 26, 2010
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
My studio monitor keeps shutting off!
It's shutting down automatically due to heat peaking. You need to turn off until you are ready to use it.
Apr 11, 2012 | Adam Audio Audio A8X Powered Monitor
Westinghouse keeps shutting off randomly
Power supply board finally dies.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Apr 17, 2010 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
Projector keeps cutting off
just in case it is overheating, blow out any dust with canned air and make sure the fans are working. also, keep anything from blocking the vents. if all that is done and it still shuts down, you have a power supply that needs replacing.
Nov 04, 2009 | Optoma MovieTime DV10 Multimedia Projector
1998 280C Benz A/C keeps kicking out
You may be low on R134a and need a simple charge. As the Compressor cycles, the low side pressure drops and if it drops to far it will cut the compressor off till the pressure rises again. The high pressure side rises and the low side drops, but when it drops to far since there is not enough R134a in the system you get the on off cycle. The other cause to this is a bad pressure switch, or bad expansion valve, and moisture in the system as it ices up in the lines and pressure builds causing the pressure switch to cut the compressor off too. Re-cap, try recharging the a/c system for now since it's still working. Good luck and keep me posted. Be glad to help.
Jun 25, 2009 | 1994 Mercedes-Benz C-Class
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
158 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
