Question about Sharp FO DC600 Plain Paper Laser Fax
We have a Sharp FO-DC600 and DC535 fax machines and need to change the baud rate down to 9600. Does anyone know how to do this?
  • Leroy Elliott
    Leroy Elliott May 26, 2010
    You can't and it still won't work on a digital phone line
Avwrexit
  • 47 Answers
SOURCE: baud rate
1. Why 9600?
Because you are using a VOIP service it can from time to time lose connection briefly. The slower the speed the less data can be loss do to network congestion. It also gives the error correcting function of the receiving fax a better chance of filling in any lost data.
9600 is a good choice becasue the industry minimum is 9600. This means you will be able to communicate pretty much any fax thats is still tickin today. Raising the speed will get you a faster transfer but will also increase the chance that you are sending data at a faster rate than the recieving fax can send.
2. How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
Basic reduces the modem speed to 9600
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps.
Posted on May 28, 2008
leroyal
  • 2120 Answers
SOURCE: need the baud rate to be 9600
fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Posted on Dec 04, 2008
POCBM
  • 121 Answers
SOURCE: Sharp Fax - Change outgoing name/number - HELP!
Try this:
http://www.sharpusa.com/files/fax_man_FO_DC500_600.pdf
Hope it helps
Posted on Mar 14, 2009
  • 48 Answers
SOURCE: Sharp FO DC535 fax will not come to ready
Turn on the fax while holding down the stop a start key, don't let go until you see 1 =all ,2=image , 3=none. Press 2 for image. If the problem persist press 1 for all.
Posted on May 25, 2009
FixinFax
  • 3085 Answers
SOURCE: SHARP F0-4400 Need to lower baud rate to 9600 on
Don't do it, it will make your machine extremely unreliable.
Fax machines are ANALOG devices and will not work on a DIGITAL phone line.
Posted on Jun 28, 2009
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
Is there a way to change the Baud rate on a Sharp FO-DC500? My phone company is telling me it needs to be @ 3200-3300?
Your phone company is lying to you.
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Nov 10, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Jun 26, 2009 | Sharp FO-4400 Fax
LIGHT IS STILL ON WHEN i CHANGED THE DRUM ON THE
clear the drum counter. life than down arow until it says drum counter clear than start 2 times
Mar 23, 2009 | Sharp FO-DC535 Fax
Dec 29, 2008 | Sharp FO-DC535 Fax
International faxing
Dial it as you would dial from a regular phone.
Ask the operator for the Country Code.
Sep 02, 2008 | Sharp FO-DC535 Fax
How many fax numbers can be stored on the FO-DC535?
You will need a larger unit with more memory 32mb.
Oct 22, 2007 | Sharp FO-DC535 Fax
Sharp FO DC600 Plain Paper Laser Fax Logo
88 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
