Question about Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Kitchen aid wall oven Model YKEBS2780B1 SHOWS ERROR CODE F2-E0
HOW DO I REPLACE THE F2 EO RANGE CONTROL/CLOCK?
Posted on Jun 24, 2010
  • 327 Answers
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
Posted on May 26, 2010
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Error code E0 F2. Now oven will not come on, but stove above works.
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock).
Jan 01, 2011 | Whirlpool RBS275PD Electric Single Oven
New Wall Oven with error code F2 EO "Keypad Disconnected" How to fi?
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Oct 18, 2010 | KitchenAid KEHU309SSS Electric Double Oven
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
Error code F2 E3 r:02 E:03
Kitchen Aid Error Code F2-E3
Called kitchen aid, they said you need a new control board part #9782455.
Mar 16, 2010 | KitchenAid KEBC107 Electric Single Oven
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
Kitchen aid oven is'nt working and giving code F2:E3 help what does it mean
Here is a page with all of the error codes for your oven.
http://www.appliancetimers.com/index.php?page=failure_code_page&manufacturer=ka&type=r
Your code is 2 parts, F2 is oven temp is too high, and the E0 wants you to test the relay contact operation. In simpler language make sure the connections are tight.
May 09, 2009 | KitchenAid Ovens
Oven not working Message E0-F2- showing
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Apr 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
688 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
