Question about AKG C414BULS Professional Microphone
My mike just stopped working, dead?
Hi there , my AKG c414BULS has just stopped working, none of the wires seem to be loose,any idea what it might be
  • 4,234 Answers
The first thing to check is the phantom power. Make sure it is there. The mic will appear dead without the power present.
Dan
Posted on Apr 07, 2008
Hi I have a 05 ram 2500 hemi. I recently had a problem with my radio came out too be my accessories wire was fried. Well when this happened my info dome where mpgs are displayed my radio and blinkers all...
You either have a loose ground wire to the dash or a bare wire touching metal on a dash bracket or firewall that is loose. It seems more likely its the latter like the wire swings away from the dash at speed and lays back against a bracket or the firewall when you stop or go in reverse. Having a fried wire is a good indicator that there is a short somewhere possibly caused by a bare or frayed wire.
Feb 18, 2015 | Cars & Trucks
AKG Q460 headphones
Those earphones, as many others suffer the same damage and it's the signal cable at one of the ends, either the 1/8 jack that goes to the audio source and/or the other end, that goes to the ear speaker piece, not necessarily should be disconnected, but it's a common fail for this tinny wires to open internally just very close at ends, because the main strssed part of this cables is precisely there, hope it helps...
Nov 06, 2013 | Music
A year ago i bought an AKG k512 headphones .I really liked them ,but like a week ago the right headphone stopped working.What to do?
Hi,it might be due to the wire that has cut inside the speaker area.
You will need to open the speaker area, and check if the wires are still in place.
And also, if the wires are intact, You will need to replace the speaker inside the headphone, That will solve the problem..
Thanks for using fixya....
Oct 28, 2010 | AKG Audio Players & Recorders
Muffled sound
I wonder how it sounds on another amp/speakers?
Did the person/shop who cleaned it test on another system and say it worked ok? A good dealer of the
AKG brand should be able to verify a problem.
Apr 14, 2010 | AKG C414BULS Professional Microphone
Akg handheld transmitter not working after impact
Microphone capsules are very delicate and I'm afraid it sounds like you have broken yours and it will have to be replaced. Take the mike back to where you purchased it and see if you can get it serviced or if they can recommend someone locally who does that.
Sep 27, 2009 | AKG HT 40 Professional Microphone
Excessive line crackling noise
The service manual is at www.akg.com/mediendatenbank2/psfile/datei/19/C4194055d1fa264a7.pdf. You will have to replace the wiring that goes to the cartridge through the gooseneck.
May 25, 2009 | AKG C419L Professional Microphone
W300i speaker stopped working, other side cannot hear my voice
Hi, my w300i speaker (mike) stopped working, my voice cannot be heard on the other side, but, when I connect the handsfree, things become fine.
Seems, the internal mike has got a problem, please suggest a remedy?
is it mandatory to get the mike changed, something similar had happened a year back and that time, they had said, that since the mike is a part of the board, the entire circuit board needs to get replaced.
Any idea, how much the board (circuit) will cost in Mumbai, India?
Mar 25, 2009 | Sony Ericsson W300 Cellular Phone
Severed cord on my wonderful headhones AKG K24P.
It sounds like you actually have 2 wires closely wrapped together. They are very fine and you have to make sure that you have separated all of the wires from each other. Generally you will have a red wire and a copper colored wire for the right side and blue (or green) and copper colored for the left side. you need to make sure that none of these little wires are still mixed with each other, otherwise you have a dead short and the speaker will not work. The insulation is very thin so there is no need to strip it, the insulation will burn off when the solder is applied
Feb 21, 2009 | AKG K 26 P Consumer Headphones
Old dynamike plus wiring for a super star 3900
1-Shield
2-White
3-Red
4-Black
Check the mike plug to make sure that none of the wires have broke off.I would also check the mike cable with an ohm meter.
Jan 02, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
AKG C414BULS Professional Microphone Logo
324 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
