Question about Kenmore Washing Machines
My Kenmore Elite Catalyst model # 11022032100 control pad problem
My Kenmore Elite Catalyst model # 11022032100 keypad control panel does nto work. I washed a load and went to check on it and the washer was flashing 11 so I figured it had 11 minutes remaining. Went back about 10 minutes later and it was still falshing 11, I pushed the start button and the washer mad a clicking noise and the panel went dead. It is completely non-responsive.
ldsaunders
  • 31 Answers
SOURCE: Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Posted on Feb 12, 2009
  • 208 Answers
SOURCE: Kenmore elite washer will not complete not complete wash cycle.
worn gears
Posted on Jun 22, 2009
carlsbiz
  • 1124 Answers
SOURCE: No Response from my washer
I dont think there is any reset button..
Try unplugging it for a few hours..
Posted on Jul 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have Kenmore Elite Catalyst Washing Machine.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE2 Plus Front Loading Washer stopped at
Posted on Sep 25, 2010
How do I reset control panel on km Elite mod #11022032100 top load washing machine?
did you check to see if the power is working first and didn't blow the breaker. then try plugging it back in. and is the machine loaded, if you can empty the machine see if it does anything
Feb 12, 2015 | Washing Machines
How do I fix a flashing Start/Resume light on a Kenmore Elite dishwasher model 665.13793K601?
These dishwashers are known to accumulate moisture in the keypad and then short. The solution that I have seen is to replace the keypad...It is possible that all of your issues with this dishwasher could point back to the keypad. After spending $$$ on the circuit boards, do you want to throw and additional $135 for a keypad? or replace the whole unit? Food for thought. Here is a link for you:
http://www.repairclinic.com/PartDetail/Control-Panel/8572855/1180767?modelNumber=665.13793K601?RCAID=1000065
May 22, 2014 | Kenmore Dishwashers
Kenmore electric stove model 95012102 displays EO-F2 the cooktop works.
that code is a bad touchpad.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1cHA0Nn50
Oct 30, 2011 | Kitchen Ranges
I have a Kenmore elite 13102 dishwasher touchpad that has begun to crack around the start button. Does this necessitate changing out the whole electronic control pad or is there a part that is the...
You will need to replace the touch pad assembly. You can purchase the part from the link below.
Kenmore elite Dishwasher Parts Link
You can read an article that explains how to make this repair yourself at the link below.
Appliance & Refrigerator Repair
Mar 22, 2011 | Dishwashers
Kenmore catalyst elite washer fills but does not
the reset is to unplug the washer for 5 minutes, if that doesn't reset it u may have a defective motor controller circuit board
Aug 02, 2010 | Kenmore Elite HE4 Electric Dryer
Machine controls are locked out and it will nto start up
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 01, 2009 | Kenmore Washing Machines
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
Kenmore elite double oven control panel
I just purchased the kenmore elite double oven with the touch pad control centre. Has anyone had any problems with the control panel on these ovens?
Dec 13, 2008 | Kitchen Ranges
Kenmore Elite drying doesn't work sometimes..
Touch pad is failing.Try not to get any moisture around this touch pad.Biggest mistake for all appliances is the touch pad and water dont mix well.
May 21, 2008 | Kenmore Dryers
Washing Machines Logo
119 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
