Question about Sharp AL 1631 Copier
MY PROBLEM FOR SHARP 5316
HOW CAN I MAKE IT CLEAR H4
  • 328 Answers
Push(# interrupt c interrupt 14 copy key)
Posted on May 27, 2010
  • 32 Answers
SOURCE: sharp ar-5316
H4 is a fuser temp error code.
Posted on Aug 28, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Error code H4-01
That error code indicates that the fuser unit isn't heating up. Try turning the power off, wait 30 seconds, turn the power on. If the error reappers the fuser unit should be checked by a technician to correct the problem.
Posted on Jul 26, 2008
  • 990 Answers
SOURCE: code H4 comes up when the sharp copier ar-5316 is switched on
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Posted on Jan 28, 2009
  • 37 Answers
SOURCE: SHARP AR 5316 error H4
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Posted on Mar 01, 2009
  • 255 Answers
SOURCE: my sharp ar 5316 photocopier displays h4. what
press # interrupt c interrupt . Display goes off
press 14
Posted on Jun 08, 2009
A problemes h4-00
H4 00 - Heat roller low temperature detection - Fuser UNIT
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key CLEAR key (c) Interrupt key
Main code [START] key Sub code [START] key
Main code = 14
Sub code = 00
Apr 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
My copier ar-5316 is flashing error code h4. pls what can i do to clear this.
check the fuser film if it damaged or not rolling if damaged replace with same make of fuser film if not see that it can roll easy
Apr 19, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error h4 sharp ar-5316 can you help me ?
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316 errors
heat roller low temperature direction
Jun 24, 2010 | Sharp AR-5316 Advanced Digital Imager...
Showing h4
If your machine is AR-5316,
Mar 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Mar 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Feb 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error H4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out andthe LED Display should go blank. If the lights do not go out, thenrepeat step 3 until they do. It may be necessary to increase ordecrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Originally posted by tryit
Dec 04, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316
I am getting a problem code H4 for sharp copier when i start the machine. what is the problem. is ther any solution for the problem of the said model.
Aug 28, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL 1631 Copier Logo
50 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
