The door lock on my Kenmore Elite 45972 is stuck in the locked position and the door is open..
  • sunnytaurus May 26, 2010
    well the entire lock piece was broken but we were able to remove it and order a new one.
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
(Tip Courtesy JSRock)
This should open the latch in your case to allow the door to be shut.
Thanks for using FixYa!!
Posted on May 26, 2010
Kenmore Elite front load washer 4110 door latch with safety lock is in lock position with door opened. How do I unlock
Solenoid prob stuck unplug machine and the plug it back in and see if it stays unlocked
Mar 01, 2015 | Kenmore Washing Machines
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he washer lock light. cannot open
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Thank you !!
May 31, 2010 | Kenmore Elite 45986 Front Load Washer
Door won't open
the lock switch is probably stuck. make sure machine is off but plugged in still. Push in on the door while gently giving a couple of thumps around the lock area and the lock will probably "click" open.
Aug 16, 2009 | Kenmore Elite 45986 Front Load Washer
DOOR ON KENMORE ELITE IN LOC POSITION AND CANNOT CLEAR
unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Door will not shut
replace failed lock asm. get the german one.
Jul 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 lock latch stuck with door open
ok nice details..all you can do is replace the lock latch,,its not to costly,,change the catch while your there,,,lock part number is,,8181700 and catch part number is 8181651..it will be better just to replace it in the long run ,,,onthejob..
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Door Lock Problem
with panel off reach up to lock location pull down on small tab door latch will click (at this point door would pop open if it were closed ) retry operation to see if ok if code dl reappear may to replace door lock if f11 may need new control module under top rear..ck wires first ..good luck
Sep 09, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
