Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
Hp monitor, same problem...
How do I get the monitor apart to replace power supply or capacitors? Can I get those capacitors at radio shack?
  • 180 Answers
Sure you can. As long as you what the value of the capacitor.
Or you bring it to the radio shack showing the sample.
If don't know how to open it . You can visit this site:
www.lcdrepair.us
There video clip inside where will teach you how to open it.
Posted on Apr 18, 2008
6ya staff
SOURCE:
Lg flatron w1943 flickering
Two things, First you need to replace all of the capacitors on the power supply board at the same time even if they do not show signs of failure because they have been under stress. Secondly, you need to use the correct ratings on the capacitors not just the mfd and voltage. Parts from Radio Shack and such will not work right and can cause additional damage to the power supply board. Here is a link to an article about getting the correct capacitors for LCD monitor repairs.
http://www.ccl-la.com/blog/index.php/capacitors/
I hope this helps,
BuddyMc
Sep 03, 2012 | LG Flatron 775FT 17" CRT Monitor
My Acer AL2017 "flashes" on then off when I hit the power on button. It does it repeatedly. If I cycle power enough times it will eventually remain on.
This is the same issue I had AND....you can fix this by replacing 5 capacitors in the screen Power Board, So here we go: go to Radio Shack or similar store that sells capacitors and buy (3) 220 Microfarad capacitors Radio Shack Part Number 272-1029 and (2) 1000 Microfarad capacitors PN 272-1032. Now on your board you will see the bulging capacitors just remove them and replace them with the new ones. PAY CLOSE ATTENTION to the polarity, there is a negative stripe on the side of the capacitor. Make sure it goes back in the way the old one came out. Now the radio shack capacitors are 35vdc and the stock capacitors are 25vdc and the new capacitors are bigger in diameter but the difference is ok as long as the Microfarads are the same. Mine were replaced and all is well now
Sep 18, 2009 | Acer AL2017 20" LCD Monitor
Samsung syncmaster 215tw monitor flickering
The capacitors BigTech referred to are C110 & C111, 820uf-25V Electrolytic, on the power supply board.
With minor soldering skills, you can replace them with Radio Shack in-store capacitors, Stock # 272-1032, 1000uf-50V Radial Lead Electrolytics for $1.59 each. Works great!
Four bucks and little bit of time saves the monitor.
Jul 01, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
My VG930M will not power up...is it fixable
In mine, there was a 1000 micro F capacitor in the power supply board that was damaged. You can tell which one it is by looking at their top. The bad one looks like it inflated and blew up.
I replaced it and it worked fine for 1 year so far.
The power supply is the one that is boxed in. You will need to remove the cover to acces the cap. I bought mine at Radio Shack for $1,59.
Good luck in taking it apart.
Jun 27, 2009 | ViewSonic VG930m LCD Monitor
Has power but a black screen lcd monitor
I have repair many Westinghouse monitors. You'll need a set of hardened plastic pry bars to remove the bezel. You'll need an ESR meter to test the capacitors in the power supply. You'll need an static isolated soldering iron the replace the capacitors. The capacitors you can get at a local radio shack. I do these repairs daily and they're not as hard as it seems.
May 30, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
HP VS19e Monitor - no power
There are three (3) capacitors that go bad on the power supply board. MAKE magazine's Instructable site has a good guide on replacing them. I have a june 07 and july 07 date monitors. they were different inside!! identical outside, however. The bulged,'bad' components were 1000uf 10v cap's, I put in radio shack 272-1032 1000uf 35wvdc. My monitors? BOTH were bought for $35 on craigslist, $10.35 in parts. ???BusinFLA -at- hotma*l dot com.....worked for me!
Jun 14, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Samsubg Monitor flickers
My samsung 740N lcd Monitor is flickering. can i get a solution of this problem?
Jun 10, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Flickering screen with a claping sound...
From other posts here the repair kit appears to be just the 3 caps and instructions to unsolder the 3 blown caps and replace ( solder back in) the 3 new caps.
Once you get the back off the monitor and start taking it apart you will see 3 capacitors- they are labeled with 470uf25v- it is the only set of 3 caps.- in the power supply ( near where the 110 power plugs in). - Go ahead, take the monitor apart- look for the capacitors- do you see them? If it looks like unsoldering them and replacing them is something you could do- give it a shot, what have you got to loose.
to see pictures of capacitors and to find way more information than you probably want to know - check out www.badcaps.net.
- bad or blown capacitors seems to be a problem with motherboards and evidently monitor power supplies also.
I ordered my caps from Mouser.com- Shipping costs about the same as a gallon of gas and I didn't have to hunt them down.
I ordered their part number 647-UHE1E471MPD6.- There are lot of capacitors of this type listed and honestly I just nearly randomly picked one with the same spec and size- but a different brand since the original ones blew. These fit the existing holes on the board exactly and were the same physical size so they didn't get in the way of any other components when I reassembled the monitor.
look at the caps carefully or take a picture before you remove the old ones, to be sure you get the new ones in correctly- there is a positive and negative on them!
My monitor has been working fine since it was repaired in January- 5 months ago.
May 23, 2008 | Princeton Digital VL1918 Monitor
My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Mar 05, 2008 | Philips Magnavox 42MF521D/37 Television
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
42 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
