Question about Carrier 52PQ307 Wall/Window Air Conditioner
I have a carrier air conditioner installed in the wall & I need to repair it. How do I slide it out?
  • Duncan Jones May 26, 2010
    This solution was helpful & i have fixed the problem
    President:
  • 1,561 Answers
Check round, most likely you see clips that are use to hold the air conditioner to its panel,unclip them and if it is screws that are used, unscrew the screws, but if none no problem. in most cases, nothing is used.
From the frame of the air condition, check to remove any bracket that is used to affirm the air condition to the wall.
Grip the the air condition by two end sides, lift it gradually and pull back or pull towards you gently. When the air condition is sliding out, you will need a helping hand, get someone to help you lift it so that you can both drop it gently on the floor.
With this, you can now carry out your repair.
Take care.
Posted on May 26, 2010
Plugs on Carrier yc273d air conditioner
You probably have a 230 volt AC that uses a different plug. If you insist on using unit there you will need an electrician to run the correct wiring and install the correct female for your unit to operate.
Jul 13, 2015 | Carrier Heating & Cooling
Why won't my Carrier room A/C stop cooling?
TO MEASURE THE AIR TEMPERATURE AT THE SAME HEIGHT AS YOUR WALL MOUNTED UNIT & COMPARE IT TO THE REMOTE CONTROL SETTING. THERE CAN BE A 8 DEGREE DIFFERENCE BETWEEN THE TWO. I HAVE TO TURN ON MY CEILING FAN TO CIRCULATE THE COLD AIR THAT DROPS AND THE WARM AIR THAT RISES.
GOOD LUCK
Aug 12, 2014 | Carrier Heating & Cooling
HOME AIR CONDITIONER LEAKING WATER
your drain lines are backed up and you either have no safety devices or they are not operating properly.
Shut the system down and clear out all your drain lines. If your system has no float switches installed anywhere, then you need to have this done to prevent any more issues.
Jan 18, 2010 | Carrier 38CKC042 Air Conditioner
I cannot find the model number on an older model Carrier Air
you should be able to remove the front cover and access the filters and a date sticker that tells the model no. The filters are likely to be reusable filters instead of disposable.
The covers of those through the wall systems are held on with clips or clips and hooks.
They can typically be removed by two methods.
1) pull the bottom out and then lift up and out.
2) lift the cover straight up and then pull out.
Some units have the filter mounted to the unit, others have it mounted to the inside of the cover.
Aug 29, 2009 | Carrier KCA101P Air Conditioner
Need to access inside of Carrier air conditioner.
After removing the cover and filter, you should be able to see the fins for cleaning. If there is styrofoam in front of the coil, it should not be there for proper operation.
Aug 20, 2009 | Carrier 52FE312-3 Air Conditioner
Need inside cover for Carrier heater/ac wall unit
Hi, since these systems are specifically sold through Carrier and Carrier dealers, then you need to go directly through them for all parts. Please call them at the following number to order the parts or find a local dealer to order the parts needed.
Monday-Friday, 8am - 5pm Eastern
Phone: 1.800.227.7437 or 1.800.CARRIER
Let me know how this turns out.
Benjamin
Jul 23, 2009 | Carrier XHD183D Air Conditioner
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
I need a remote for a carrier bca-101r wall unit. Or a compatible remote.
Get model number and call place of purchase or carrier customers service.
Mar 19, 2008 | Carrier BCA101R Air Conditioner
Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Carrier 52PQ307 Wall/Window Air Conditioner Logo
47 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
