Question about HP Color Inkjet cp1700ps Printer
No Yellow I have cleaned and cleaned and cleaned and primed... but the yellow ink was light and all the colors had lines through them. I got the yellow blocks to print better, but when I print a page say from the web, there is no yellow. I replaced the cartridge but still no yellow.
  • Dae327 Apr 07, 2008
    Can you explain why? What is the problem and can it be fixed?
  • 3 Answers
You need to buy a new printer.. (tiger21)
Posted on Apr 07, 2008
I have cleaned and deep cleaned the printer a number of times but when I do a print check the yellow line does not print neither does the black line under it print. When I print anything else the yellow...
If a line doesn't print, the ink is out of the cartridge for that inkjet cartridge color. Replace the cartridge. Deep cleaning can use a lot of ink up at a time.
Nov 11, 2010 | Canon Pixma iP4500 InkJet Printer
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
Canon pixma mp830 not printing yellow.
This just started happening to me also, I have been using the printer without issue for a few years. Replaced the yellow cartride, still no yellow. Anybody else seeing this?
Feb 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I can't produce green colors. I have cleaned the printer head with no impovement. Can this part be replaced? How would I know if the problem is electrical and not physical? Peter
I assume by cleaning you mean pressure FLUSHING the ink channel with cleaner, not just wiping the head. You have to charge the ink channel after flushing to prime it.
The cost of a replacement part probably makes it un-economical to do a replacement.
Testing for electrical problem without schematics would be hard.
Do check that the flex carriage cable connection is good.
Nov 02, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
No ink is getting to printhead in imagePROGRAF w7250
Your printheads are indeed clogged. (Note: all ij printers should be powered off when not in use! This retracts & seals your printheads.) Now, on to your problem. In your printer software, there should be a maintenance section. In there, you need to clean the printheads - this may have to be done *many* times - like 10-ish to clear (if still possible) clogged ink.
Hope this helps.
Cheers,
gurutim
Mar 19, 2009 | Canon imagePROGRAF W7250 InkJet Printer
Problems with color prining
hi!!!!
perform maintenance and
try to clean up nozzles may be the ink
clog
or removed the cartriged and clean with alcohol
use cotton buds then placed it back properly
Oct 31, 2008 | Canon BJC 2100 InkJet Printer
1220c Ink blockage
Sometimes the nozzles get clogged. If several normal cleaning cycles do not clear all the nozzles, next try removing the cartridge and setting it, nozzle-side down, on a steaming-hot damp paper towel for a few minutes, then running a cleaning cycle. If this doesn't solve the problem, as a last-ditch effort the head can be soaked in a shallow dish of alcohol for a few minutes. This cleared up a clog for me that no other method would solve, but I have heard that if soaked too long in alcohol, the head may be damaged.
Nov 15, 2007 | HP DeskJet 1220c InkJet Printer
HP Color Inkjet cp1700ps Printer Logo
87 people viewed this question
Ben Johnson
