Question about Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37
This is supposed to be a vertually clog free toliet, first time used, out comes the plunger. is there a way to put more water in the tank?
  • 2,100 Answers
You can only go to the top of the overflow pipe. Is it up that far? The filler is adj, just lift up on it, and the water level will come up. Usually how they work. Check it out.
Posted on May 27, 2010
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Delta Home
Garbage disposal and possible clogged drain
plug the one side of the sink so as to create a sealed enviroment for the plunger to work weffectively ... plung the open side ..
If this does not work , try running a metal coat hanger thru the outlet at the disposal exhaust line.
Mar 25, 2013 | Electrical Supplies
OLD TOLIET
this might sound wierd, take a brick or two and put it in the cistern (the water tank) then the brick will displace the water and you'll use less water
Sep 15, 2012 | 1992 Chevrolet S-10 Blazer
Bought a american standard toilet tank to replace our leaky tank. after installation and turned on the water, but the tank is filling very slowly. what could be wrong?
Actually sounds like trash in the toliet water valve.....or possible that if teflon tape was used to seal threads has been drapped accross inlet threads and caused blockage......Best way to check this is to take supply line loose from toliet and slowly turn water on while pointing the supply into a bucket or something to catch the water and see if the pressure is ok......Then check valve to see if grit or blockage is in the toliet valve.........Depends on valve design to whether or not you will be able to clean....may have to replace toliet valve with new one......hope this helps
Sep 05, 2011 | American Standard Home
Vax carpet washer deluxe leaks from bottom of water tank, somewhere between coming out of the tank and going into the jet to squirt on the floor. pissing me off - any help would be great!
This is a common problem known by repairers. What happens is residue gets stuck in the seals. The next time you use the machine and press the trigger the seals stay open and water leaks continually. It was suggested that maybe after you finish using the machine you do a whole tank of plain water to rinse it out but I haven't had any luck with that. I am stuck with a machine that doesn't work.
May 06, 2010 | Vacuums
Toto toilet has weak flush
Check water level in tank and also under rim off toliet bowl where water come's out. Make sure level in tank is right and it has ports all around rim. they can be clogged up also.
You can use a roofing nail to stick in ports it is several around under rim that you can't see but are there where water comes out. Because if the ports some are stopped up it will restrict proper amount of water to certain areas.
Apr 13, 2010 | Toto Aquia II Dual Flush Toilet
Toilet Question
Yes, it will run up your bill! Sounds like the float is hanging up. Take tank lid off and flush, watch the float and if your tank fills quickly but does not stop, bend the float arm to angle the float down further, this should allow your water to stop coming in much quicker. The other possibility could be if the plug at the bottom does not seal correctly after flushing, if so, the water will leak until the plug sits down all the way.
Apr 11, 2009 | Kohler K-4709-96 C3-200 elongated toilet...
Tank will not refill after you flush
okay depending on the type of toilet ball **** (i know its a funny word, but it's really what its called.) you have one the most standard type is the long wire with the big ball on the end. you need to adjust this ball **** so it goes lower test it out, flush your toilett and wait till the water drains then when its supposed to come back up push down on the ball **** and youll see the water will start to fill, so then adjust the little screw on the fill valve (the other side of the floater where its attached)
you may need to shut off your water supply and drain your tank depending on how skilled you are,
pretty simple work, if you have questions feel free to ask.
Nov 16, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Not spraying liquid.
This is where you attach the Lego.
Nov 13, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37 Logo
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
