Question about Dimplex DS5603 Heater
I have a dimplex cxl24n that is not working
I have a dimplex cxl24n storage heater that is not working correctly, the booster/convector works fine but the economy 7 side wont work. All other heaters in house working fine, can anyone help please.
SOURCE: I have two dimplex XLN storage heater, it was
It sounds as though it has tripped the internal cut-out - this can be manually reset quite easily by yourself. It would probably be best to ring Dimplex customer services on 0845 6005111 to get them to talk you through it step-by-step though.
Posted on Dec 21, 2009
SOURCE: dimplex dual night storage heater/convector heater
runs for 30 seconds then shuts off
Posted on Jan 23, 2008
SOURCE: my dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Posted on Feb 13, 2009
SOURCE: My dimplex night storage heater is not heating up,
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Posted on Jan 19, 2010
  • 2464 Answers
SOURCE: Hi 1 of my economy 7 heaters has stopped working
Hi in side the case on the left hand side there is a reset looks like a flat pieceof metal push this it will make a loud click this should reset heat , turn heater off first
Posted on Jan 21, 2010
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
How to operate an economy 7 heater
storage is when it stores up heat at night and convector is when you use it in the day , best I can tell you .
Oct 21, 2011 | Heating & Cooling
Hi I have a night store heater model 79168 in my new home and no idea how to use it!! Please help :)
Here is a good article for Dimplex, a storage heater manufacturer, that explains the the theory and how it works. I'm sure you will find it interesting. http://www.dimplex.com/storage_heaters#
Basically, thermal storage heaters heat ceramic bricks during off peak hours (during the night), store the heat to be used during peak hours (during the daylight hours), when electricity is more expensive per kilowatt hour.
Hope this helps you.
Apr 18, 2011 | Heating & Cooling
Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Jan 16, 2010 | Dimplex Heating & Cooling
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
Dec 19, 2009 | Dimplex Heating & Cooling
I have two dimplex XLN storage heater, it was working last year but after someone put damp clothes on it, they are not working, could you help me please
Dec 18, 2009 | Dimplex DS5603 Heater
Hi, Last night none of the Dimplex storage heaters in my home came on. I checked the fuse box and nothing has been trippped. They were working fine the night before and I cant think of any reason why they...
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
Dec 15, 2009 | Dimplex DS5603 Heater
Dimplex storage heaters dead
sir please check the heater connection inside.then check if there are any damages in the control cables.
Mar 07, 2009 | Dimplex DS5598 Mid-Size Heater
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Dimplex DS5603 Heater Logo
714 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
