Question about Kenmore 64902 Electric Dryer
I own a GE #DVL223EB1WW electric dryer that is approx 7 yo. The terminal block was replaced about 1 year ago. Now, the block needs replaced again. Is this a chronic problem with GE electric dryers?
  • 15,935 Answers
What do you mean by terminal block?
Where the wires are connected from the outlet?
Is this a 3 or 4 wire connection?
Thanks!!
Posted on May 26, 2010
  • gwork8800 May 26, 2010
    A terminal block connects the 3-wires from the power cord to the dryer where other wires are connected to the other side of the block that run the machine; i.e. motor, timer, start/stop.
Where to I connect the 4th lead (green) from a 4-wire cord to a DPSR483EA GE Profile dryer?
oldtech2332_102.jpgThe green ground wire goes where the linkage from the center terminal on the terminal block is...removed that linkage from the white wire center terminal on the code block and install the green wire to where the linkage connected to the cabinet
Sep 11, 2011 | GE DPSR483EA Electric Dryer
General Electric DVL223EB1WW Electric dryer no longer heats up. Still blows air, cold, but no heat?? Any suggestion?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 15, 2011 | GE DVL223EBWW Electric Dryer
Replaced heating element and it still wont fire up
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 02, 2010 | GE DVL223EBWW Electric Dryer
Have ge dryer changing from 3 prong power cord to four prong need diagram
The main difference between a 3-wire and 4-wire configuration is how the Neutral and Ground wires are terminated at the temrinal block. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
In a 3-wire configuration Neutral (WHITE) and Ground (GREEN or BARE COPPER) are terminated TOGETHER at the terminal block via a ground strap.
In a 4-wire configuration these two wires are independent of each other are NOT terminated together.
If you have questions, please let me know. I hope this helps you.
Nov 28, 2009 | GE DBXR463EBWW Electric Dryer
Ok got a GE DVL223EB1WW Insufficent Heat
Yes think so , what should happen is element heats up controlled by fan blowing cold air across it this then heats to whatever thermostat is set to switch at, which in turn controls heat level..Air is then exausted via hose to waste unless its a condenser drier which then turns the steam back to water / which is collected in a waste condesate drum..hope this is helpful...
Nov 19, 2009 | GE DVL223EBWW Electric Dryer
GE Dryer not producing heat
First, replace the door switch. Second, check the wiring of the new cord. It should be as follows:
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Third, if you still have no heat, make sure there is strong air flow out the vent outside the house when the dryer is running. If all that is good, check for 240 volts to dryer. (dryers can run the motor on 120, but need 240 to heat). Comment back (including model number) if you have further questions.
May 22, 2009 | LG DLE7177 Dryer
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Electric dryer internal short
Make sure that the dryer is disconnected from the wall outlet before doing any repairs on it. Electric dryer work on 240 volts AC and this could hurt or even kill you. loose connection on the terminal block will cause the wires to get hot. and melt the terminal block and wires and the pig tail wires. you will have to replace the terminal block and pig tail wires and make sure you use the correct bolts and make sure you tighen them. let me know if this helps.krazytech
Sep 09, 2007 | Magic Chef CYE4000AWW Electric Dryer
Replacing a defective Terminal Block - Kenmore Dryer
If there are any lose wires connected to the dryer terminal block and there is any sign of current draw like black around it or if it just looks bad in general then yes it does pose a threat of a fire hazard or electrical hazard like shocking you when u touch the frame. There is a terminal block you can buy for it visit any part place with the model number and they can help you out hope this helps
Jan 08, 2007 | Kenmore 64892 Electric Dryer
Kenmore 64902 Electric Dryer Logo
187 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
