Question about Acer Aspire 5100 Notebook
Pointing device my pointing device has stopped moving
I need some help connecting another pc in my home . I have one pc connected with modem & wireless router attached & all is well with the two of them . Need hep with connection of a second desktop pc in another area of home !
Posted on Sep 15, 2008
THANK YOU , YOUR GREAT , I'VE HEARD & MINE PROBLEM WAS SOLVED WITH F7/F4 @ THE SAME TIME . I MEANT TO PUT IN ON THE SITE , I KNOW YOU WILL LET THEM KNOW ! I WILL KEPT IN TOUCH WITH YOU !
Posted on Apr 09, 2008
    Genius:
  • 1,027 Answers
Check the FN + one of the F keys, mine is FN+F9, my other laptop is FN+F2
Why did it suddenly stop working?
the "pat answer" is the magic smoke leaked out. all electronics work on magic smoke, once it gets out of a device, the device wont work anymore. OK smoke comes from burned out devices. Point the remote at a digital camera and watch through the view finder, does the led in the remote light up? (you cant see it with the human eye) if so next step. plug the dongle into the TV, select the correct input and point the remote directly at the window on the dongle and try to operate the fire stick, if it works, you may need an HDMI EXTENSION cable (male to female) to move the dongle to a position where it isn't blocked from the view of the remote. Also, can you operate it from your computer using Google Chrome and the correct firestick extension? (incase the remote isn't infrared operated)
Apr 03, 2016 | Amazon Fire TV Stick
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Aug 04, 2011 | Tissot PR50 Sport Chronograph # T34152852...
My acer mouse stops working after the laptop has been on for about ten minutes, then if you try to move it the screen just zooms in and out
Hi
i would go to computer properties
device manager
scroll down to mouse/pointing devices
un install it
then restart the laptop
windows will then hopefully find new hardware when it re starts
and reload the touchpad/mouse correctly
many thanks
Mar 21, 2011 | Acer Aspire 5535-5050 Notebook
How do you replace ink in EPSON TX110? Paul
The procedure is shown on the panel you can see if you open the cartridge compartment of your TX110. However, it can take some effort to decipher the icons. It is known to work if the ink low light is on, untested otherwise.
  1. Turn on the printer.
  2. Press and hold the STOP button until the cartridge tray moves out of its bay. It will stop at the ink low notch pointing to the first cartridge out.
  3. Press STOP again. The cartridge tray will move to show you the next cartridge low on ink.
  4. Repeat until you know all cartridges out. After the last cartridge pointed to, the tray will move again and stop in the area where all cartridges can be accessed by hand.
That's it folks!
Nov 12, 2009 | Epson Stylus NX400 InkJet Printer
The mouse screws-up in normal mode after a little while - the pointer stops moving but items will high lite when you move the mouse. The mouse doesn't have any problems in safe mode. Problem started after...
The mouse is not the problem. The problem is with your mouse driver. It might be damaged. Try deleting the mouse driver and reinstalling it. Assuming you have Windows XP. Go to Start>Settings>Control Panel>System>Hardware>Device Manager>Mice and other pointing devices.
Delete all pointing devices, close everything, restart the computer and the system will detect the mouse, follow on screen instructions and install a new mouse driver. That will fix the problem.
Aug 25, 2009 | Microsoft Windows XP Home Edition English...
Touch pad stopped working for my gateway laptop
laptops always have an option that says wether to use the internal pointing device (your touchpad) or an external mouse or both, enter system preferences and make sure that your internal pointing device is enabled
Jul 23, 2009 | Gateway Computers & Internet
Car over heating when stopped in traffic but not when movin
Hi. the first test will be to open the hood and inspect the cooling fans. check to see if the fans are activating in intervals during the running cycle. if you don't see any fan rotation at all, this will confirm cooling fan failure and you will need to replace the fans or fan relay. Now, if the fans are running and the car is continuing to run hot when stopped, i would move to the next inspection point. the next problem spot will be a faulty water pump or faulty thermostat
If these two devices are malfunction in any way, it will cause the symptoms you are experiencing. at this point. the first thing is to make sure those fans are actually working.
Please rate and have a great day:)
Apr 28, 2009 | BMW 318 Cars & Trucks
Synaptics pointing device ceased to function
Check Device Manager to see if the trackpad/mouse is listed. Check BIOS menu not disabled Check you have no 'palm-check' hot keys which disables the trackpad (to avoid moving mouse when you are typing)
Jul 22, 2008 | Toshiba Satellite A135-S2246 Notebook
Message saying alps pointing devive has stopped working, can still move mouse pointer but cant use the scroll function
A possible fix for the Alps problem Your Alps pointer problem is probably driver related. To fix it:
1. Open Windows Explorer
2. Right click on Computer & choose properties
3. Open Device Manager (Admin password may be required)
4. Under Mice & other pointing devices, right click Alps pointing-device & choose Update driver software
5. Choose Search automatically & it will download and install the latest signed driver from the windows repositories & hopefully that will fix that problem.
Jun 14, 2008 | Computers & Internet
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER stopped working
What are you trying to connect your USB wireless device to?
Is it to a wireless hot spot?
or to a Wireless Access Point/Router?
When you find a connection, what is the signal strength?
I assume you have configured your Access Point correctly as well as making it secure. You should connect a computer to the Access Point using a network 10BaseT cable to check the Access Point configuration, especially the wireless configuration.
If you are trying to connect to a wireless Access Point and you have a weak signal, move your computer closer to the Access Point or move the Access Point to a better and higher location to give you a better wireless coverage. Note, walls can affect the wireless signals between the Access Point and the wireless network card and wireless USB device, especially reinforced concrete walls.
Jun 01, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
