It could be a problem if you are running a 32 bit operating system. I know that there is a limit of around 2gb on any 32bit windows install. this can be fixed by installing a 64bit version, IF your hardware supports it. You would need a 64bit cpu to install 64bit windows. If this is not the reason you are having the problem, the only other reason that would make sense would be that your motherboard doesnt support more than 1gb of ram per DIMM hence it shows that two are insalled but can only use one gb each. This i think is the more logical answer because I think the limit on GB for win 32bit was more like 3gb. good luck
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.
The FIX.
Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Have you checked to see if there are any pending software upgrades that have not been done or have started and not finished. A lot of the time that is the problem. Also check to see if your security is scanning and is not finished.
your TV tuner is incompatible with win7 , however you can work with only by installing it's win7 driver. i have a 8400gs VGA and if i don't install it's win 7 driver, it won't work properly!
Boot her up with a xp cd in the cd/dvd drive. She will take boot sector from there. Problem is that you mounted a SATA drive on an old IDE motherboard and used an additional PCI interface card that misfires
too fast or to slow to get xp's boot sector. Had such a case under my hands few months ago. This was the solution there.
Copied xp to a separate DVD and uses this to boot system, pc will only use boot sector from this and then use installed sata drive. Once fired up you can tempoerarily remove that CD/DVD and use for tasks.
Your problem lies in an older BIOS or older component. Maybe there is a later version.
BIOS flashing is tricky. Be sure to have backup before flashing. No experience leave it.
