Question about IBM Infoprint 6500 Matrix Printer
Display reads processor halted novram error 3
  • rmeade555 May 26, 2010
    Cleared nvram, reloaded boot settings, all is well now.
Phaser 7400 14: real time clock
According to my service manual, this error is occurring during the Power On Self-Test. While it is a "soft" error, it normally can only be resolved by replacing the Image Processor Board.
But wait! There's more!
Here may be a way to reset without the expensive replacement:
The most likely cause is that the Image Processor Board has not successfully loaded
its NVRAM contents (instructions) into RAM. All print engine operation halts, and
will only become ready when the Image Processor Board successfully boots.
1. Check for media or debris in the paper path.
2. Power cycle the printer.
3. Verifying Image Processor Board failure:
a. Power-off the printer, and remove the Image Processor Board.
b. Power-on the printer. Wait at least 5 minutes while the print engine
initializes. If there was a problem with the Image Processor Board, it will
now not affect the Engine Control Board.
c. If characters appear on the Control Panel display, the Engine Control Board
is functional and the problem is most likely with the Image Processor Board.
d. Turn off the printer and reseat the Image Processor Board and turn on the
printer to determine if seating was the problem.
e. Perform a PostScript NVRAM reset, see "Postscript NVRAM Reset" on
page 6-9.
f. Turn off the printer and systematically remove individual optional
components from the Image Processor Board to isolate a possible problem
component.
g. Replace the Image Processor Board.
I wish you luck with this repair.
Dec 07, 2014 | Xerox Phaser 7400/DX Laser Printer
PROCESSOR HALTED NOVRAM ERROR 3
it means one of the pin is not inserted in slot check the processor inserted currectly or not..
Jun 25, 2014 | Office Equipment & Supplies
Novram error 3
Main PCB has failed and will need to be replaced. There are 2 styles make sure you get the same one.
V5
MRP provides IT Parts Product Supplies and Services
V6
Mar 26, 2014 | Printronix P7210 Matrix Printer
Processor helted novram error3
V5
V6
Feb 19, 2014 | Printronix P7220 Matrix Printer
My board does not turn on and its beeping. Ive counted 7 beeps. i tried replacing the memory with known good ones but still the beeping persist.
MSI states that 7 beeps means "Virtual mode exception error "
Explanation: Virtual mode is one of the different modes that the processor can run in. The system is reporting an error when testing this mode.
Diagnosis: There is a problem related to the processor or motherboard. Note that this doesn't mean that the processor is necessarily dead, since the system won't boot at all with a dead processor.
Not knowing the price of either your processor or the board it is hard to say what to do for the best
Good luck
AMI Beep Code Deep Code Description 1 short DRAMS refresh failure 2 short Parity circuit failure 3 short Base 64k RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed AWARD Beep Code Deep Code Description 1 Long, 2 Short A video error has occurred and the BIOS cannot intialize the video screen to display any additional information
Jun 19, 2010 | MSI K9N6PGM2-V Motherboard
Processor in incorrect slot system halted error
You don't see this often but when you do it means your cpu is not in cpu slot 1. (Usually you are also running 1 processor in your server.) Just move the cpu to the other slot, power on your server and you should be good to go. Be sure to only touch the edge of the cpu and not any of the chips in the middle.
Good Luck
C2Solutions
Mar 02, 2010 | HP Compaq ProLiant 800 Server
1801-microcode patch error
Hi according to HP memo see the following answer hope it help:
DESCRIPTION After installing a different system board or processor in systems described in the "Scope," the systems may halt during POST and display an 1801 Microcode Patch Error with a prompt to press the F1 key to continue.
NOTE Pressing the F1 key will allow the system to continue. However, processor performance may not be optimized and the error will repeat each time the system is restarted. HP recommends that the microcode be updated to ensure optimum compatibility and performance.
Sep 09, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
5B Interface or Device(s) Error, System Halt
It could be Memory module problem which is fixed in 5B slot (or) 5B slot itself may have the problem,
Mar 14, 2009 | Acer Altos 1100 Server
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
IBM Infoprint 6500 Matrix Printer Logo
897 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
