My moniter will not shut off when I shut the computer down. Am I doing something wrong? serial # S18F5068946
  • 449 Answers
You can turn off the monitor from the power button. but if this is the first time this is happening then you must install the driver for the monitor vga so the system unit can be able to control it
Posted on Apr 07, 2008
Question about my HP desktop model p6-2003 computer blue light on and moniter going to sleep moniter going to sleep
in control panel, select the power Options,, Change the preffered plans to HIGH PERFORMANCE then click on change plan settings, change turn of diaplayto never and put computer to sleep never... Remember to turn on your screen saver and put the pc to sleep manually when not using it.
this is a common problem and caused by corrupted registry entries. The popper fix is to reformat or restore the system.
Dec 29, 2012 | Computers & Internet
Moniter shuts down while playing wow while not in windows mode
Go to your computer's Control Panel, Power properties, and change the power scheme to Always On, where hard disk shutdown, monitor turn off and system suspend are all set to "never". This should help.
Dec 26, 2009 | Xerox XA7-17i 17" LCD Monitor
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
HELLO, I have a Toshiba laptop note book computer, Satellite A15-S127...INTEL CELERON 2.0 GHZ With USB 1.1 made in 2003 and a slot for PCMCIA Cardbus... I already have a second moniter (externaly)...
Suggest you buy and install a USB 2.0 adapter card.
Example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Sep 06, 2009 | Computers & Internet
Moniter flashes message and shuts down
Try updating your monitor. Go to a Best Buy store or Circuit City store near you.
Apr 12, 2009 | Computers & Internet
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Monitor blinks no image
first you need to isolate the problem to either the computer or the moniter. I would sugust that you hook a know good moniter to the compter and go from there. If the other moniter works then you have a moniter issue aif not chek the video card in the computer. good luck
budman630
May 01, 2008 | E-Machines eMachines Monitor E15T4
Moniter won't come on
hi
check your ram.put ram away and check your bip is comes on or not .if u get long bip your cpu is ok.and your ram pro.
clean your ram and fix it again.
clean oyur processor case.
clear your bios .
pls take step one by one.
Mar 24, 2008 | AOpen F90JS (Black) 19 in. Flat Panel LCD...
Will not close down
These monitors go into a standby just incase you are only restarting the PC.
To turn it off properly, hit the power button on the monitor before Windows has completely turned the computer off.
IE: tell Windows to shutdown, when you see the blue screen telling you Windows is shutting down, turn it off then.
Hope that helps
Oct 20, 2007 | Acer AL1715 17" LCD Monitor
Computers & Internet Logo
19 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
