Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Briggs and Stratton (Quantum 35) Mower Engine stalls
My Mountfield rotary mower is about 10 years old. It has been regularly serviced. Recently, it starts OK but when hot "hunts" (i.e. the engine speed changes at constant throttle and it lacks power). Eventually it just stalls with a "pop" from the exhaust. I have replaced the plug, checked the carb jets and float chamber and adjusted the mixture. I haven't yet de-coked it or checked (if there is one) the governor. Any ideas greatly appreciated.
rockitman187
  • 2559 Answers
SOURCE: Honda IZY engine hunts. I mean the speed pulses rhythmically!
Just adjust the idle speed control/Fuel air screw located pointing downward on the bowl of the carb,Just start the engine,idle up high and turn the screw until it levels out and runs smooth.
Posted on Jun 03, 2009
  • 154 Answers
sounds like air leaking into the intake.replace the gasket that is in between the carb and the block
Posted on Jun 13, 2009
mowerman1857
  • 389 Answers
SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Posted on Sep 14, 2009
  • 152 Answers
SOURCE: oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
Posted on May 25, 2010
  • 10865 Answers
SOURCE: i have a problem keeping a 16 horse power briggs
hi Scott. The problem you are having is not due to the screw settings. It is due to a partially gummed up carbeurator. Get a can of carbeurator cleaner and add the recommended amount to the fuel tank. Also get a can of starter fluid and an assistant. While you start it up, have your assistant spray some starter fluid into the air intake area of the engine. Keep spraying the starter fluid until the problem clears and the engine takes off on it's own without any more starter fluid. Joe
Thanks for choosing Fixya!!
Posted on Dec 02, 2010
Manual for briggs and stratton 12000 series mowers quantum
B/S makes the motors for several brands of mowers. Go to the web site and search your model for a download.
Oct 07, 2014 | Briggs & Stratton Quantum Lawn Mower...
Repairing a Briggs and Stratton Quantum 35 mower engine. How do you replace the metal starter pawls in an older Briggs & Stratton mower engine
take cap off drive the pin out the bottom from the top replace starter pawls and springs put back to gether drive the pin back in checking making sure not to thight if it is drive pin back some until it spins freely
Aug 22, 2014 | Garden
Servicing a briggs & stratton 35 classic
Clean exterior of engine and frame. Remove and sharpen blade. Clean blade compartment, scrap off old residue and wire brush. Repaint if necessary. Replace spark plug with new. Drain oil and replace with new - DO NOT OVERFILL!!. Replace air filter with new after cleaning filter compartment.
Jun 30, 2014 | Briggs & Stratton Garden
Where can i get a manual for a briggs and stratton pwr400prma 35 classic petrol rotary mower
You can download a manual for the engine from Briggs & Stratton's web site - you just need the numbers off the blower shroud. No manual exists for the actual mower.
Sep 12, 2009 | Garden
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Jul 25, 2009 | Garden
Briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Jul 01, 2009 | Champion International Champion& Small...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
719 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
