Question about Acer AL1916W 19" LCD Monitor
Acer AL1916W won't display
After a I shut down my PC and reboot, the monitor, an Acer AL1916W, comes off standby and flashes from a black screen to a grey/white screen and back to black. It may do this a couple of times but does not begin to display. I've tried to turn it off, unplug it, disconnect it fro m the PC but no good. Once by turning it off and back on the ACER logo came up and all was well. Now it won't display at all. Is it toast or am I missing something?
Bogdan
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
Smooth_Gecko
  • 125 Answers
SOURCE: problem with the acer al1916w
If the displayed logo is good, but windows is not, it suggests a problem with the windows graphic driver or windows itself. In the early stage of boot, it uses a graphic display from the BIOS. This changes to the Windows display as it gets on its feet. If you have Knoppix or some bootable CD/DVD, try that. Then you will know if it is Software or hardware.
Posted on Aug 02, 2007
SOURCE: Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Posted on Jan 12, 2008
  • 408 Answers
SOURCE: why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Posted on Mar 06, 2009
budmrtn
  • 11361 Answers
SOURCE: Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 25, 2010
Screen stays black but lit when shut down
If the monitor led is indicating stand by and it seems as if the monitor is still on, could be a sign of an aging monitor. As long as the led changes along with the function of the monitor there's really no way to indicate the monitor still on after shut down especially when the led is amber telling you it's on standby mode.
Mar 01, 2014 | Acer Aspire Zs600 All-In-One Desktop Pc,...
Lcd monitor is flashing on & off
This monitor is expeicencing a defect on the backlight and the assembly behind it. The backlight may need replacing or you could just buy another monitor.
Hope this helps.
Mar 15, 2010 | Acer AL1916W 19" LCD Monitor
Standby light comes on but does not activate Monitor screen
if you are getting a standby lights it means that the monitor is working fine, better yet if have a spare working computer try pluging it there, if you have a display, then have your previous cpu check for any problem a hardware or device failure is causing these problems
Nov 21, 2009 | Acer AL1916W 19" LCD Monitor
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Display problem
>Run a HDD self test>If pass
>Install the OS that should take care of the issue.
If the HDD fails replace the hard drive
Jul 03, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W no sign of life.
If Power LED lits up and then turns to orange (standby mode) but no display, pls check SMT fuse (F200), replace the caps and replace 40T03GP power mosfet N-channel enhancement mode. Good luck
Apr 26, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
Acer monitor AL1916W question
Stand on your head ??? put the stand on the other end ??
Jus kidding ? Is it a monitor that offers a rotate screen feature ??
Did you buy it used ? almost sounds like the screen is in upside down which is possible but a bit tricky to do.
Sep 25, 2008 | Acer AL1916W 19" LCD Monitor
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
