Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
My pm800-m2 computer does power up but no beep and signal although i have changed my psu and cpu.
  • 1 more comment
  • Adnan Bhatti
    Adnan Bhatti May 26, 2010
    If the fans run and still it fails to display then take it to a repair service and have its boot chip flashed otherwise its probably done; get a quote for repairs or buy a new one.
  • soultru Jun 01, 2010
    http://www.google.com/search?hl=en&r...
    So I had a look inside the tower and noticed a burned connector on 1 of the ram slots (attached to motherboard) and 1 black mark on the gold connectors of the ram stick. I guess this was the prob. So I have taken the stick out but the pc still doesn't work, it does not beeps to say the stick has been removed, but do you think I can put a higher ram in the 1 slot that works and leave the other slot empty? I also noticed that the fan is faulty as i tried it on another computer it beeps and then the computer swicthes off. What can i try next.?
    President:
  • 1,566 Answers
Have you already checked the pin connections? You need to make sure that its according to what is stated on the manual. Also, try to swap the memory on different slots. If you have a spare memory or ram, test it on the motherboard as well. Another thing is the CPU fan. Make sure that it is seated properly and is not loose.
Posted on Jun 01, 2010
  • soultru Jun 02, 2010
    I have checked the pins and secured the fan still no response.
  • 6,993 Answers
check your RAM and your VGA card (if any). If the ram is not recognized by the motherboard, there is be no display at all. Also the VGA card.
So, remove the ram, clean the ram slot on your motherboard s there might be dust on it, check your VGA card if it is well fixed. Also check your VGA cord, is might be damaged, Check the pin on the cord to be sure its intact.
Do general troubleshooting your the motherboard and there should be a difference. But if there is not difference, then I think its high time you got another motherboard.
Lastly, test all the components of the motherboard with another motherboard in other to know precisely where the problem is coming from.
Be more patient with the motherboard and you will definitely get a solution.
Good luck.
Posted on May 26, 2010
  • 1 more comment
  • soultru May 26, 2010
    If the fans run and still it fails to display then take it to a repair service and have its boot chip flashed otherwise its probably done; get a quote for repairs or buy a new one. Can you show me where the boot chip is seated on the pm800-m2 diagragm?
  • soultru May 27, 2010
    I have changed my psu, cpu and now recently have checked my external vga card on another comtuper it works fine. I have two rams, one have discovered it is faulty as one of the connecting point is missing on it and the other seems not to be recognised although on another computer it works fine, thus how do i troubleshoot the ram slots?
  • soultru May 31, 2010
Help.
The motherboard will work with a Radeon graphics card as long as it is a PCI-E card. Your problem is more likely to be either a weak PSU or a badly fitted CPU. make sure the CPU fan is connected and runs at switch on and that you have used thermal paste on the CPU/heatsink mating face. Then check your PSU is serviceable. You can get a PSU tster for a few pounds or dollars form most online computer parts suppliers.
May 04, 2013 | Biostar MCP6P-M2 Motherboard - v6.0,...
Time and date changes daily to january 3
there is CR 2032 or CR 2016 installed on the mother board open the cover of ur cpu and u can see that battery installed like coin simply change it and it will be fixed
pls let me know if i fixya problem
Feb 25, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Overclocking the cpu
eneble cpu overcloking from bios settings, but I do not recomand this cause you might fry it..:P so...reboot , press del to enter bios settings ..choose cpu setings by pressing enter , choose overcloking ...sellect by pressing enter ..at the end ya press F10 and yes to save and reboot
Jan 07, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Continous beep every 6 seconds
There is either a problem with your memory or your BIOS settings. Did you recently change any settings in your BIOS? If so try resetting it. You may refer to the motherboard user Guide for help regarding resetting your BIOS/CMOS settings. If you cant find it you may also try to remove the CMOS battery on your motherboard for a few hours and then connect it back this should have reset your BIOS.
If you are sure you havent changed any settings then there may be a problem with your RAM or the slot in which the RAM is connected. Check it by using a spare slot on your comp. If it does nt work then you may have to replace your system RAM.
Oct 27, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
ECS PM800 Restarting?
defragging uses a lot of disk drive space and memory. while you encountered a problem during the process of defrag, you may experience some data corruption after the startup, thus, your computer wont boot... only remedy for that now is to do a reformat.
Apr 29, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
New board will not install com ports 1 & 2 and lpt1 printer port & floppy dr A
what you should have done was uninstalled the old motherboard drivers first as these drivers will be running the board although incorrectly, if you still have the installation disc run it as if to install, but it should show up with the option to uninstall the drivers.
Sep 26, 2007 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
225 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
