Tv says fan 2 going out ! Picture is starting to fad away!
    President:
  • 1,099 Answers
If the picture faded away on the order of 10-20 seconds (and if it comes back, also comes up to full brightness in same time frame - possibly with the persuasion of some careful whacking) AND with NO other significant changes such as size, focus, etc., then take a look in the back of the tube for the filament to be lit - the orange glow near the CRT socket. If there is none, then you probably have a bad solder connection on the circuit board on the neck of the CRT. Look for fine cracks around pins on that board. Try prodding it with an insulating stick to see if the picture comes back. Resolder if necessary. Dirty or corroded CRT pins/socket contacts can also do this - remove, inspect, clean, and replace the neck board. It is probably not a bad CRT as the filaments are usually wired in parallel and all would not likely go bad at the same time.
However, if only a single color fades in and out, then a bad connection inside the CRT is a distinct possibility - look for only one of the filament's glow to be coming and going. This is probably not worth fixing.
If the picture faded away with other symptoms, then there is probably a fault in the video amplifier/output one of its power supplies - still probably a loose connection if you are able to get it back by whacking.
Good luck
Posted on Jun 01, 2010
Phillips TV Fadding picture
you need to replace color wheel..
Jun 14, 2012 | Philips 50PL9126D/37B 50" DLP TV
Have lamp cooling fan noise on Samsung HLP5063W - 50 when I turn on TV and screen is distorted. Noise on TV is gradually getting worse and now does not go away and I essentially have no picture. Do I need...
the problem with your tv is the color wheel
not the fan let me know if you need help to take it apart...
I do repairs for samsung tv and I fixed a lot of them before..
Jul 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Fads to green with spiraling lines
you may have a short in the picture tube. but from your description it sounds like the positor has failed. really hard from your description but if the positor has failed its very cheap to replace..farr64
Apr 27, 2009 | Televison & Video
While down loading maps the 76CSX just quit. The batteries are good. When I turn on the GPS it starts then fads away like there is no power, yet I have tryed 2 sets of new batteries.
It sounds like a corrupted upload. Reset the unit and retry the upload.
Usually reset is done by pushing page and enter while powering up
Apr 22, 2009 | Garmin GPSMAP 76 GPS Receiver
57 IN. TOSHIBA HDTV
YOU HAVE BAD CRTS. THOSE ARE RETRACE LINES YOUR SEEING CAUSED BY SHORTSINSIDE THE CRTS. BUY A NEW SET.
Jan 08, 2009 | Toshiba 57H81 57" Rear Projection...
Sporadic Hum on HLP4663W
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Jun 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Picture fads to Blue after a 30 minutes the picture comes back with a blue tint.
yeah you need a tech to adjust the bias of the picture tube if you are lucky that fix it other wise the blue picture tube is bad
Apr 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound Problem
If you are feeding the VCR signal into the antenna connector,then you could have a problem with the sound circuit drifting off frequency. If you are feeding the VCR signal into an "A-V" jack then you could have a problem with the audio amplifier inside your set. The circuit board would have to be tested to determine where the exact problem is located. Stargazer
Jan 08, 2007 | Daewoo DTQ-27S2FC 27" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
