Question about Reebok Vista Treadmill - RBTL13305
My reebok vista treadmill stops after a few minutes running on it. During any speed it simply seizes and stops.
  • hattiemat May 26, 2010
    My reebok vista treadmill runs fine when no one is on it. But as soon as I get on to run it stops suddenly after a few minutes. The motor sounds fine, no strange noises.
  • hattiemat May 27, 2010
    This response was very informative and gave me some basic steps to take to further troubleshoot the problem.
  • 10,515 Answers
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 26, 2010
  • 506 Answers
Check to see if the motors are running. if it is producing any noice before it stops working. If yes you need to replace the motor
  • Nicholas Enyika
    Nicholas Enyika May 26, 2010
    It could also be that the belt is lose, Check out these areas and make sure that these Items are okay. If any of these Items are faulty of loose tighten them or replace accordingly.
  • Nicholas Enyika
    Clear the setting you have on the Treadmaill by recyling power to the treadmill. Reprogram for the number of munites you want and start.
Why does my reebok 8400c treadmill stop after a minute or two? The control panel works, but the tread will stop. I can start it manually, but it stops again after 1 or 2 minutes.
You have to check the speed sensor potion. Try to align the speed sensor or check is there is any dust accumulate on speed sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 27, 2016 | Reebok Exercise & Fitness
I have a Reebok Competitor RT8.0 treadmill less than 2 years old. Consistently, every 4 minutes and 10 seconds it will stop & then in a few seconds resume the same speed? I have replaced the...
this happens to do the lack of maintenance schedule, and the machine shut down, for to protect the electronic system.
LUBE inmediately the DECK belt, maybe you have a WORN deck belt, time to replace the deck belt.
Try again, and test it
God bless you
Oct 15, 2012 | Reebok Exercise & Fitness
We have a Reebok Vista Treadmill and it turns on but none of the controls work including the ones for the TV?
adjust the reed switch, see the diagram attached, clean, and tigh the connector very well.
Try to RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you
Apr 28, 2012 | Reebok Vista Treadmill - RBTL13305
I have a Reebok Vista treadmill that has NOT been used that often. We turned it on the other day and the only button that worked is the start. We could not change the speed or the incline etc. Any ideas...
Dear Sir:
I will help you inmediately: Check the circuit breaker to see if it hastripped. If the reset/off circuit breaker has tripped, wait 5 minutes andreset.
    • 2
If the power cord is properly plugged in, unplugit and wait 5 minutes before plugging it back into the surge protector.
    • 3
Remove and reinsert the console key. 4)Remove the key from the console and UNPLUG THE
POWER CORD.
5) Next, remove the screws from the hood
and carefully remove the hood. Locate the Reed Switch
and the Magnet on the left side of the Pulley .
6)Turn the Pulley until the Magnet is aligned with the Reed
Switch. Make sure that the gap between the Magnet
and the Reed Switch is about 1/8". If necessary, loosen
the indicated Screw , move the Reed Switch slightly,
and then retighten the Screw.
Re-attach the hood and run
the treadmill for a few minutes to check for a correct speed
reading.
Thank you in advance,blessing, if you need some additional assistance please reach me. sincerely.
E.CUADRA
Managua, Nicaragua. C,A
Sep 13, 2011 | Reebok Vista Treadmill - RBTL13305
How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Mar 07, 2010 | Reebok Exercise & Fitness
I have a 6 year old Reebok RX5000. At speeds
They walkbelt is most likely worn out causing too much friction overheating the motor.
Jan 15, 2010 | Exercise & Fitness
Reebok Vista Treadmill issue
Have a 2 year old Reebok treadmill. Control panel was replaced right after we bought it. Now, again, the upper half of the panel works but we are not allowed to start anything. Does the whole panel need to be replaced again or is there a fuse or something small that we can do.
Jun 07, 2009 | Reebok Vista Treadmill - RBTL13305
Reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
May 28, 2009 | Reebok Vista Treadmill - RBTL13305
Reebok Vista Treadmill - RBTL13305 Logo
826 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
